Old 08-07-09, 11:27 AM   #1
SUPERSTARDJ01
Question Engine noise
Hi,
I took out the missus on Sunday for the first time for both of us and since then I think the SV sounds different almost more mechanical if that makes sense a little noisier and chuggy when at low speeds? It used to have a little whistle at speed but no more.
Idea?
Old 08-07-09, 11:36 AM   #2
Spiderman
Where the hell am I?
Spiderman's Avatar
Default Re: Engine noise
Checked you engine oil level recently?
Old 08-07-09, 11:43 AM   #3
Engine oil level, carb balance.
Old 08-07-09, 12:44 PM   #4
SUPERSTARDJ01
Oil level has dropped slightly but still well with limits, should I do an oil change?
Old 08-07-09, 01:23 PM   #5
Spiderman
Spiderman's Avatar
Depends when it was last done of course but i cant see it being responsible if there is enough of it.
Old 08-07-09, 01:48 PM   #6
Holdup
What sort of slow speeds? revs below 3k in 2nd gear and or above? thats when my likes to complain.
Old 08-07-09, 01:50 PM   #7
Alpinestarhero
Wouldnt harm to top up the oil to be towards the upper limit...I notice my bike is louder when the oil is halfway or lower. An oil change would help, especialy if the oil is a bit old (greater than one year) or the bike has seen quite a few miles since the last oil change (greater than 5000)
Clean and lubricate the final drive chain aswell, i found that helps reduce noise.
Old 09-07-09, 10:51 AM   #8
SUPERSTARDJ01
Oil is only 5 mths old and has done just over 1000 miles, it's low speeds any gear around 5-35mph and a slight power loss between 3k and 5k rpm but it has more of a nocking noise now you can really here the pistons pumping away mainly from the front of the V twin, if that makes sense?
It's almost like a chugging tracktor.
I'll see about put up a sound bite or upload a video to youtube so you all can see what I mean.
I should also add it's just over 15k on clock so could be tappets?
Old 09-07-09, 11:16 AM   #9
sv_rory
Where abouts in mk are you? a very good friend of mine is a bike mechanic so I could ask him to pop over for you and have a listen.
Old 09-07-09, 11:33 AM   #10
merlin427
When I take my wife out in the car I get a whining noise from the passenger seat if I corner quite heavily but this goes away when she gets out so probably not much help to you!
engine noise. cmc1 SV Talk, Tuning & Tweaking 24 12-06-08 11:32 AM
Engine Noise Torn-Thorax SV Talk, Tuning & Tweaking 1 02-12-06 07:56 AM
odd noise from engine weazelz SV Talk, Tuning & Tweaking 3 01-09-06 09:11 AM
Engine noise Sudoxe SV Talk, Tuning & Tweaking 6 10-07-05 10:25 PM
Engine noise SPeeeeDY Bikes - Talk & Issues 7 27-03-05 02:10 PM
