Old 10-07-09, 11:47 PM   #1
ooger
Default I said I wouldn't and I have...
...not serviced it according to the bible of Suzuki.
Regular oil changes every 3k miles - check
Scottoiler fitted after only 500 miles - check
Chain checks as per the Haynes bible - check
New front and rear tyres after a little bit of rearwinter slidiness - check
Levels and fluids are checked regularly
ACF50 - as required
Regular washings - as much as is (domestically) permitted
So here I am. Riding it and liking every mile of it - about 200 miles a week, but am I neglecting it? Will it rust me out? Probably.
I probably will never sell it - having read the stories of "your" first bikes(!) - but I may get another one, what the "other" is - who knows when, who knows what.
Whats most important, nowadays (given the above), and 12000 miles from the dealership fromwhenceitcame, in your opinion?
(Please do not recite the bible of Haynes to me - I have that - I'm looking for the "well, they dont tell you this...." sort if information")
As always,
Thanks
Old 11-07-09, 12:22 AM   #2
Stu
Trinity
Stu's Avatar
Default Re: I said I wouldn't and I have...
So, 12K miles & servicing consists of 4 oil changes? nowt else?
Old 11-07-09, 07:12 AM   #3
Alpinestarhero
Oil changes are very important, I change mine every 6 months / or between 4-5000 miles (i.e. after another 4000 miles I realise I need an oil change soon and will start finding the time to do it!). Spark plugs you would have wanted to change at least once by now. Scottoilers are great but still rmember to inspect the chain and do clean it, because crap will still stick to it.
How old is the bike? Has the engine coolant been changed? What about brake fluid (I've gone through loads of brake fluid on my bike )? Inspected the brake pads for wear?
Anyway, you keep it clean in all departments, so thats not a bad thing
Matt
Old 11-07-09, 08:48 AM   #4
Bri w
Bri w's Avatar
You're doing the stuff that makes it go. Don't let rattles go unchecked.
Make sure you check the stuff that makes it stop - sometimes you need to stop more than you need to go!
Old 11-07-09, 10:05 AM   #5
Clean and grease the suspension bearings BEFORE they are rusted solid.
Clean and grease the brakes BEFORE they sieze.
Oil filter? Coolant change?
Old 11-07-09, 10:28 AM   #6
ooger
Sorry - omitted the various oil filter changes that have also been done with oil changes.
Its a 57 bike, so is coming up to its second winter. No coolant changes have been done yet.
Brake fluid levels are fine and the brake discs seem in good condition. I don't ride it hard. The brakes do exactly what I want at the moment and I never ask them to do too much.
The chain is in good condition, but I don't degrease and regrease it perhaps as often as I should.
The front disc however is starting to sound a bit scratchy, now and again.
Old 11-07-09, 11:11 AM   #7
Stu
Trinity
Stu's Avatar
What happens if you never change the coolant?
Old 11-07-09, 11:24 AM   #8
The coolant has corrosion inhibitors in it which get used up over time. Otherwise parts can corrode.
Old 11-07-09, 08:06 PM   #9
Biker Biggles
Biker Biggles's Avatar
Sounds to me like you are doing just fine.Id add that the valve clearences need checking every 16000 miles and you should take a good look at the brake pads to ensure they have meat on them.Bit of oil in the cables to keep them sweet wont go amiss.Personally Id not get too worked up about the coolant for a good couple more years,but the brake fluid change is worth it.
Old 11-07-09, 08:17 PM   #10
Alpinestarhero
+10,000
Its a right pain in the rear end, trying to get seized retaining pins out of a rear caliper when its cold and you and your dad are hungry.
