Old 22-07-09, 09:16 PM   #1
thefallenangel
Default ticking noise as the bike is being wheeled around.
Hi there,
Was wheeling my bike back into my motorbike shed and i heard a ticking noise and i'm pretty sure it was my rear wheel bearings gone. I had my cush drive off when i had a new tyre put on and the bearing looked shot but i greased it up hoping it would fix it but it's gone now i think.
Is there any other possiblity its something else?
Old 22-07-09, 09:20 PM   #2
shifter
Default Re: ticking noise as the bike is being wheeled around.
That's usually an indicator the sprocket is reaching the end of its days.
Does the chain adjust up ok? and also how far can you pull the chain away from the sprocket?
Old 22-07-09, 09:21 PM   #3
thefallenangel
sorry new C+S 2k ago. And the 3 o clock thing is okay, minimal (if any) movement.
Old 22-07-09, 09:23 PM   #4
shifter
face the rear sprocket and go to the 3 0'clock position on it. Can you pull the chain far enough away from the sprocket to see daylight through the gap?
Old 22-07-09, 09:23 PM   #5
thefallenangel
doesnt move.
Old 22-07-09, 09:24 PM   #6
Biker Biggles
Biker Biggles's Avatar
If you already know the rear wheel bearing is shot I reckon thats likely to be your problem.It needs fixing so Id start there.
Old 22-07-09, 09:24 PM   #7
can also be a brake pad lifting and falling in a caliper on a high spot on a disc...
Old 22-07-09, 09:25 PM   #8
shifter
I'd give the bback brake a good look over next then.
Old 22-07-09, 09:25 PM   #9
thefallenangel
Okay. Anything i can do about it? Don't really want to have to replace a disc?
Only cleaned the back brake 6 months ago and added braided lines too. Grrr.
Old 22-07-09, 09:26 PM   #10
ejohnh
You prob have checked this but is the chain dry? If the links are stiff you will get all sorts of weird noises when you wheel the bike,
What's that ticking noise? :/ dyzio Bikes - Talk & Issues 3 30-12-08 03:03 PM
HELP! - Bike Not Starting (Ticking Noise) ianc SV Talk, Tuning & Tweaking 21 05-03-08 12:51 AM
Ticking Noise in engine jamesnolan Bikes - Talk & Issues 24 12-12-07 12:03 AM
ticking noise dougieo SV Talk, Tuning & Tweaking 12 30-05-06 09:18 PM
Ticking noise...... Davies Bikes - Talk & Issues 20 07-03-06 10:25 PM
