Old 28-07-09, 10:12 PM   #1
DavieSV
DavieSV's Avatar
Default Lucky?
Had a set of pp2ct's delivered Monday morning.
I was going to fit at work them last night, but the misses gave me some negative feed back about the cost
so after a little ..discusion.. I could not be bothered.
Today I felt the rear tyre squirm under hard acceleration at nearly full lean, but thought I was pushing it a bit too hard.
Rolled it onto the ramp this morning to remove the wheels & discovered a screw straight through the center of the rear tyre. Rear pressure was down to 23 psi when I took it off.
Does everything happen for a reason?
DavieSV is offline   Reply With Quote
Old 28-07-09, 10:19 PM   #2
Default Re: Lucky?
yes..usually because life is being a biatch again
Old 28-07-09, 10:33 PM   #3
RichT
Default Re: Lucky?
Of course it'll be your fault the screw made it's way into your tyre - just after you bought new rubber.
lucky lucky bugger or karma... tonyk Idle Banter 7 29-03-08 04:07 PM
Lucky dip! Blue_SV650S Idle Banter 20 27-01-08 01:19 PM
Crash.NET - McWilliams 'lucky, very lucky'. NewsBot News 0 09-03-07 04:50 PM
Lucky or what? Whitty Idle Banter 6 26-05-06 10:21 AM
Lucky, lucky Ireland !! Supervox Idle Banter 6 19-03-06 09:41 AM
