Hi guys,
I have k5 naked . what should the front preload be ? i looked today and they are flat with no rings showing at all . ? im around 6 foot and 14 stone with all my gear on . all standard setup . Cheers , ant .
2006-2007 -- Gilera Runner 50 - Sold 2007-2008 -- Hyosung XRX125 - Stolen 2009-2010 -- 05 SV650n - CAT - B 2010-Now -- 00 SV650s & 00 SV650n & GSXR 600 K2 |
it is written in the owners manual, something like four or five rings out of seven showing.
isnt it diffrent for diffrent weight ?
#4 | |
i think it you start from standard and then measure the sag you will be able to determine whether you need to turn the preload up or down.
At your fourteen stones, that's the right setting - but it's the wrong spring.
The standard springs are suitable for someone rather smaller than you.
You have yours set hard as possible
http://www.gostar-racing.com/informa...ion_set-up.htm Check front preload there, follow the guide it will help set your bike up for your weight dont worry about the rest other than rear preload, SV's dont have adjustable damping compression etc |
im really dumb when it comes to things like this lol ... how manny rings need to be showing with me wieght then ??
#9 |
Basicly
Put a cable tie on one or both fork stanchons (the shiny bits) Put the cable tie(s) closest to the dust seals Go for a ride then look where the cable tie(s) are if they are more than 10mm away from your bottom yoke remove 1 preload (so it comes out) you will see a line then adjust the other side so they both have one line showing, go for a ride, repeat process removing 1 preload each time untill you have close to or 10mm distance between the bottom yoke and the cable tie. this will then set the front up for your weight. Be careful, you may find that the bike will tip in more than you are used to so take your time. Last edited by Holdup; 31-07-09 at 11:48 AM. |
#10 |
As Sid Squid says. Having the preload set with no rings showing i.e. all the way down is the right setting for your 14 stone weight.
Basically the springs in the standard SV650 are set up for a 10 stone rider so you need to wind the preload in all the way if you ar 14 stone. In the future you may want to look at replacing the stock springs for slightly stiffer ones.
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. |
Sag and preload etc | AndyBrad | SV Talk, Tuning & Tweaking | 12 | 20-06-09 06:59 PM |
What do i need to convert the 1999 (no preload adjusters) to having preload adjusters and progressive springs. | sv_rider1990 | SV Talk, Tuning & Tweaking | 12 | 11-07-08 05:15 PM |
Front preload query | simesb | SV Talk, Tuning & Tweaking | 12 | 03-07-08 04:42 PM |
Front Spring Preload | big twin grin | SV Talk, Tuning & Tweaking | 1 | 13-04-06 05:44 PM |
Front preload caps on pre 02 model | Fuzz | SV Talk, Tuning & Tweaking | 14 | 08-09-05 06:43 PM |
