Old 31-07-09, 12:07 PM   #1
curium
Default Gearbox problem
Hi
I have a 2006 SV650S totally standard apart from a GIVI rack.
Recently it's started making a clacking sound and I'm experiencing temporary loss of drive when accelarating hard in 1st gear.
This only occurs in 1st gear when accelarating hard.
If I accelarate more modestly there are no problems.
None of the other gears are affected.
I'm going to study my Haynes manual tonight but was hoping someone with experience could point me in the right direction so I can decide if it's worth repairing.
Cheers for any help!
Old 31-07-09, 12:30 PM   #2
Holdup
Default Re: Gearbox problem
How old is your CSK? Slack chain? teeth knackered on the sprockets? can you move the chain side to side and pull it off the rear sprocket?
Old 31-07-09, 02:31 PM   #3
warrenhewitt10
yeh id say check the chain, if its too loose and the sprockets are worn u may find its jumping over them..hence the clacking
Old 31-07-09, 05:12 PM   #4
fastdruid
fastdruid's Avatar
I've found the front sprocket nut can work loose even if it's been locktighted, correctly torqued up and the tabbed washer done up properly...
I'd also check that.
Druid
Old 31-07-09, 11:26 PM   #5
curium
Cheers guys! The bike is still on it's original chain and sprocket and has done 30,000 miles so this could well be an issue.
The chain can't be pulled right off the rear sprocket but comes away to reveal daylight. I'll have to get the cover off to check the state of the front sprocket.
Old 31-07-09, 11:29 PM   #6
warrenhewitt10
jeees id say thats long overdue!! unless uve got a scottoiler and even then thats lots! i changed my chain and sprockets at about 12,000 miles the first time, then bought an x-ring and have dun jus short of 9000 miles on it and its been adjusted twice small amounts lol so id reccomend those when ur changing
Old 01-08-09, 10:49 AM   #7
Don't go for a cheap X-ring instead of a good O-ring.
Go for tsubaki, or DID.
Old 01-08-09, 06:20 PM   #8
warrenhewitt10
my x-ring is tsubaki and it cost more than the o-ring! haha
Old 01-08-09, 06:40 PM   #9
That's what I mean.
I am saying don't go for a cheap X ring, because a good quality O ring will outlast it.
Then again, if you maintain your chain, I'm not at all convinced of the benefits of X rings.
Old 01-08-09, 06:42 PM   #10
warrenhewitt10
oh sorry i do apologize lol i took it the wrong way! what ive read about them sounds fairly convincing, but i haven't had it long enough to test how long it will last but judging by the wear it gets in the time ive had it id say it will be quite a while before i have to change it
Serious Gearbox problem :( silent11 SV Talk, Tuning & Tweaking 46 05-09-08 10:37 AM
Gearbox Richie Stuff Wanted 0 09-07-07 08:09 PM
Gearbox Fix? seandixie SV Talk, Tuning & Tweaking 11 29-06-07 09:32 AM
Gearbox problem??? shortie SV Talk, Tuning & Tweaking 1 14-05-06 02:20 PM
Gearbox Daglad SV Talk, Tuning & Tweaking 12 02-04-06 09:26 PM
