Old 04-08-09, 01:03 AM   #1
XJimmy
Default Removing restriction
So I've finally passed the two year mark and have days off work. I wanted to remove it myself to save a bit of money. The bike is a 2001 sv650s and the papers from FI international states it has blades fitted in the inlet manifold. I was just wondering; is it as easy as just removing these blades and fitting it back together or is there something else that I should be aware of? Thanks
Old 04-08-09, 06:52 AM   #2
Geoffrey
Default Re: Removing restriction
lift the tank, remove the airbox, lift the carbs and you will see the plates sat between the carbs and the engine inlet.
this is all i had to do when i restricted my sons, that too was an f1 kit if i remember rightly.
Old 04-08-09, 06:57 AM   #3
Spanner Man
Good morning.
As Geoffrey says it's pretty simple to do. Take your time, & just make sure you don't drop anything down the inlets whilst you have the carbs off.
Cheers.
Spanner Man
Old 04-08-09, 07:08 AM   #4
Alpinestarhero
There are some words you might wish to use when you discover the simplicity of the restriction kit.
Such words I can't post on here you will feel cheated, thats for sure!
Restriction GeneticBubble Bikes - Talk & Issues 18 23-06-12 10:23 PM
Removing FI-Internation restriction kit Wester SV Talk, Tuning & Tweaking 4 07-07-09 08:05 AM
New restriction suzsv650 SV Talk, Tuning & Tweaking 6 20-04-09 10:25 PM
Restriction Jebiah Bikes - Talk & Issues 3 11-07-06 09:11 PM
33 bhp de restriction HELP andy gooding Bikes - Talk & Issues 33 19-02-06 12:01 PM
