Old 08-08-09, 10:55 AM   #1
TSM
The Sick Man
TSM's Avatar
Default For PBX Geeks
1) anyone here deployed asterisk in their company
2) employed e164 or DUNDi for their PSTN numbers
3) using a HD codec g722, g729 or g711u/a
Old 08-08-09, 02:46 PM   #2
Iansv II
Default Re: For PBX Geeks
I understood pstn.. thats about it
Old 08-08-09, 02:49 PM   #3
asteroids in Dundee with pasta using High Def glue
Old 08-08-09, 02:51 PM   #4
Foxy
Not used any of those, mind you I have mostly worked on military networks.
G.703 and G.711 is mostly what was used.
Old 08-08-09, 03:02 PM   #5
Baph
1? Yes. 2 & 3? Na-uh.
Sorry.
From memory, EnumLookup() will be your friend for e164, ie something along the lines of this in extensions.conf:
exten => _1NXNNXXXXXX,1,EnumLookup(${EXTEN})
(that will probably require DNS changes too).
DUNDi I've never touched.
As for your codec's, G.772, G.729 and G7.11 u-law /a-law should be pretty much supported out of the box, check:
Code:
core show codecs
Other than that, not much help from me unfortunately.
Old 08-08-09, 03:34 PM   #6
TSM
The Sick Man
TSM's Avatar
Sorry.
Code:
core show codecs
I am already using * on a test bed at the office. Ive got enum setup already, no DNS changes required, register the numbers you require at e164.org and ready to go. I use G711 as bandwidth is no problem for us internaly, G722 when the polycoms talk to echother for hi-def, dont need G729 as i dont have the correct licence to transcode on the server. I use FreePBX as the GUI front end so for the mostpart i dont need to mess around with the config files and i need to make sure that other people can use it.
geeks- help me Quiff Wichard Idle Banter 24 30-01-09 11:27 AM
Oi geeks. yorkie_chris Idle Banter 64 23-11-08 10:06 PM
Any IT geeks in here Cam_73 SV Ecosse 18 29-02-08 05:15 PM
So then Geeks Viney Idle Banter 4 06-08-07 11:21 AM
Something for the geeks.... Baph Idle Banter 81 16-11-06 04:46 PM
