I know the cam swap is discussed to death, but I haven't seen much talk about possible use of the new Gladius camshafts. Here is the information I found on them:
Intake valve duration is 281 degrees, with 9.0 mm of lift. Exhaust valve duration is 267 degrees, with 8.3 mm of lift. http://www.bikersweb.co.uk/features/...ArticleId=1996 That's another nice step up from the K3+ 8.7 mm (279?) and 7.3 mm (267?), with inlet to exhaust swap 8.7 (279?) and 8.1 mm (270?) and certainly a nice step up from the 8.1 mm (270?) and 6.1 mm (247?) of the Curvy. Possible problems, different springs, too much tuned for low revs? Any thoughts on this? EDIT: rough estimate would be another 2-3hp over the K3 cam swap?
'02 (Curvy), yellow, Sport Smart, mods: progressive fork springs, '03-04 ZX-6RR rear shock, Li-ion battery, Leovince slip-on, Powerbronze airflow double bubble, flush front indicators, bike-it integrated LED rear. SRAD front end conversion on going. Last edited by CSpronken; 14-08-09 at 05:26 PM. |
Also check the new lift doesn't result in valves mating with pistons!
Was: K2 naked in rapid yellow ![]() Now: Street Triple R |
#3 | |
EDIT: This post seems to indicate that the 8.9 one would need new springs.
'02 (Curvy), yellow, Sport Smart, mods: progressive fork springs, '03-04 ZX-6RR rear shock, Li-ion battery, Leovince slip-on, Powerbronze airflow double bubble, flush front indicators, bike-it integrated LED rear. SRAD front end conversion on going. Last edited by CSpronken; 14-08-09 at 04:24 PM. |
would it not be easyier to do the dangerous dave sv800 coversion
Nope!
800cc really needs an aftermarket crank and aftermarket barrels. REALLY expensive (you could easily buy 2 TLs for that price)
So they wouldn't be a straight swap?
Not yet confirmed, there might be issues with piston clearance and the valve springs have changed, not sure how that would work out.
'02 (Curvy), yellow, Sport Smart, mods: progressive fork springs, '03-04 ZX-6RR rear shock, Li-ion battery, Leovince slip-on, Powerbronze airflow double bubble, flush front indicators, bike-it integrated LED rear. SRAD front end conversion on going. |
Buy some and turn by the enginehand... If it dont turn you know they contact. Then you can slot the cams and alter the timing to make them work.
#9 | |
it is not that easy, you need proper minimum clearance between valve and piston, not just it turns over. |
#10 |
Here is a comparison of a K3+ and Gladius valve and springs. They are exactly the same in this diagram except for the second spring, but could also just be that the diagram is not the most accurate?
![]() K3+: http://www.suzukipowersports.com/fic...003&fveh=10157 Gladius: http://www.suzukipowersports.com/fic...009&fveh=28491 Only the the G1 and G2 bikes have the same piston part number, gladius seems to have new pistons, so perhaps the new pistons are needed to have enough clearance?. 02: 12111-20F00-0F0 03+: 12111-20F00-0F0 Gladius: 12111-44H00-0F0 ![]()
'02 (Curvy), yellow, Sport Smart, mods: progressive fork springs, '03-04 ZX-6RR rear shock, Li-ion battery, Leovince slip-on, Powerbronze airflow double bubble, flush front indicators, bike-it integrated LED rear. SRAD front end conversion on going. Last edited by CSpronken; 14-08-09 at 07:37 PM. |
curvy cams | josal | Stuff Wanted | 2 | 04-11-08 11:41 AM |
Pointy (or maybe curvy) cams | Spoon | Stuff Wanted | 0 | 13-04-08 01:03 PM |
Fitting later model cams to a curvy. | Blue_SV650S | SV Talk, Tuning & Tweaking | 10 | 08-04-07 05:37 PM |
m4 curvy exhaust system/k3-k6 cams | rupert28 | Stuff Wanted | 0 | 26-03-07 08:25 PM |
K3> exhaust cams for sale, also carbed model intake cams | northwind | For Sale - SV's and SV related items | 0 | 14-09-06 11:04 PM |
