Old 19-08-09, 10:19 AM   #1
adam15
Default Fuel/Air Mixture Screw problem
Hello all,
Just an enquiry as to whether this is a known problem.
I was trying to adjust the fuel/air mixture as the bike is running a bit rough at idle and very rich (reduced fuel consumption) but the screws (on both carbs) dont move either way.
Is this a common problem with them seizing up?
Old 19-08-09, 12:03 PM   #2
Default Re: Fuel/Air Mixture Screw problem
Yeah they do sieze in.
If an adjustment hasn't caused the problem, it probably won't fix it. I would suspect the choke plungers.
Old 19-08-09, 12:10 PM   #3
adam15
Thanks, it was setup for a different exhaust and that was changed so needed to adjust the fuel/air mixture on the carbs, choke plungers seem to all be ok.
Im going with the 'may require another pair of float bowls' then, with moving screws I hope
Old 19-08-09, 02:11 PM   #4
The screws aren't in the float bowls, they're in the body.
Old 19-08-09, 02:15 PM   #5
What exhaust was on it? Even a full system doesn't generally need the screws adjusting much differently to stock.
What mains is it on? Stock is 137.5 if they've had a full pipe and a decent air filter on they'll probably be 150+ mikunis or dynojet 170+ size. Stock pilot jet is 17.5 but again this is generally OK with a pipe and filter so no need to change it.
Whip the choke plungers out and have a look at them as this is really common that they don't return properly and make it run rich. Also the carbs being a yard out of balance will affect economy as one cylinder will run rich, the other one will run hot.
Fuel pump problem, maybe. mudgutsdunn SV Talk, Tuning & Tweaking 5 11-03-10 11:54 PM
Fuel system problem metalmonkey SV Talk, Tuning & Tweaking 10 15-09-08 07:49 PM
mixture screw, which way for richer ?? boo86 SV Talk, Tuning & Tweaking 11 16-08-08 11:50 AM
Adjusting fuel/air mixture Stormspiel Bikes - Talk & Issues 0 08-09-06 09:40 AM
Fuel Light Problem Bez SV Talk, Tuning & Tweaking 8 08-05-06 01:04 PM
