Old 20-08-09, 01:36 PM   #1
Default LED number plate light
what would make my number plate light flicker? its all wired correctly Ive checked 3x my first led plate bulb started to have an intermittent flicker so i changed the unit now the new ones doing it? its annoying the sh#t out of me and I'm on the verge of putting the snow plow back on
Old 20-08-09, 01:54 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: LED number plate light
R&G light provided with a Tail Tidy?
Mine started doing it ages ago - have tried to remove it and cant - will need to get a replacement THEN cut this one off...
So basically if it is then, "They all do that Sir"
Old 20-08-09, 01:57 PM   #3
the first one to go wasnt an R&G it was one off eBay, the current one is an R&G one so i dunno?
Old 20-08-09, 05:36 PM   #4
do they need a different voltage? or can they be wired straight in? my stock plate bulb plugs in and works no problems.
Old 21-08-09, 02:12 AM   #5
monkey
Gotta be a wiring thing if the leds are ok. Check and clean the connections and see how that does you.
A fella down here once had his led indicators tinkling whilst polishing the bike with pledge just from the static!
Old 21-08-09, 05:36 AM   #6
Geoffrey
if all the wiring is good i would hazard a guess they need some form of resistor
Old 21-08-09, 06:29 AM   #7
Mr_Chin
Kwak, are you sure it's not shorting out somewhere along the line? I'd be inclined to check the whole line of wiring for the light. The wire may have been chafing against something, and now the bare wire is intermitently earthing itself against the frame/metal causing it to flicker.
This advice might be a whole-lotta-bull, but you never know
HTH
Chin
Old 21-08-09, 08:37 AM   #8
no it makes alot of sence thanks, i'll check that out
Number Plate Light for a K6 metalmonkey Stuff Wanted 2 31-01-08 01:14 PM
K5 number plate light quikstu For Sale - SV's and SV related items 2 25-10-07 09:26 AM
'99 Number Plate Light Grainger Stuff Wanted 0 11-05-06 04:20 PM
number plate light. kwak zzr SV Talk, Tuning & Tweaking 9 08-04-06 06:23 PM
Light for my number plate? RenamedMonkey SV Talk, Tuning & Tweaking 0 11-06-05 10:00 AM
