Old 23-08-09, 09:32 PM   #1
I'm_a_Newbie
Question Primer for Forks
So today I drilled out the front mudguard bolts so I could repaint the forks on my K3. I got the mirco thin layer of powder off and got all the corrosion off. I used standard grey primer, let it dry and started the top coat. It did not go well so i tried to wipe off the top coat with kitchen towel. As is did this the primer coat peeled off with it.
Is there a special primer for aluminium?
I got all the primer off again and started polishing one of the forks instead to see what it looks like, not sure polished forks suite the K3 onwards.
Tim
Old 24-08-09, 01:08 PM   #2
jambo
jambo's Avatar
Default Re: Primer for Forks
The forks are cast from a form of aluminium alloy. You can buy a special metals primer made by Halfords, Hammerite also manage something similar.
I believe Lozzo simily wet&dried his and then applied Hammerite smooth straight onto the forks.
Jambo
Old 24-08-09, 01:46 PM   #3
lee67
i wet and dry'd my bandit forks and sprayed em hammerite smooth black...looked great and no issues
Old 24-08-09, 02:58 PM   #4
Dangerous Dave
Don't bother painting them, you will have to redo this whole process again in a few years. Strip them down and polish them, no need to lacquer them as an occasional wipe down with ACF-50 or WD40 will keep them corrosion free.
Old 24-08-09, 08:12 PM   #5
madness
If you're going to paint aluminium, first you really need to grit blast the surface. Then apply an Etch Primer before applying the top coat.
Old 24-08-09, 08:13 PM   #6
Dave20046
Dave20046's Avatar
seconded, so I would follow Ddave's advice if I was you.
USD GSXR1000 k1 forks | standed forks - curvy Nicky S SV Talk, Tuning & Tweaking 113 07-09-09 01:12 PM
forks jon8oy SV Talk, Tuning & Tweaking 26 04-12-07 08:34 PM
TL forks Jester666 SV Talk, Tuning & Tweaking 11 16-11-07 10:52 AM
USD forks ejtrent SV Talk, Tuning & Tweaking 5 01-07-07 07:31 PM
Forks Help Full Throttle SV Talk, Tuning & Tweaking 0 04-01-06 08:11 PM
