Old 30-08-09, 01:06 PM   #1
BomBalong
Exclamation How to Wire Hein Gericke Flasher Relay
Hi people,
im in need of some help ( Yes i have searched the forum with no luck ).
today i bought the hein gericke flasher relay ( 3 pins ) today and had a look in the sv's manual and it doesnt seem to just plug in??? the guy at the desk said that it should just plug in, but im pretty sure that its not possible can anybody please shed some light as to what im todo.
Thanks,
Ben.
Old 30-08-09, 01:16 PM   #2
BomBalong
Default Re: How to Wire Hein Gericke Flasher Relay
Old 30-08-09, 02:25 PM   #3
BomBalong
BUMP,
can some-one just let me know what wires go where to the relay please, it has a L pin, B pin and a E pin, im only asking so i dont screw it up just a double check if you will.
thanks.
Old 30-08-09, 03:37 PM   #4
Dave20046
Dave20046's Avatar
Originally Posted by BomBalong View Post
BUMP,
thanks.
My flasher unit is the two pin sort and as there are only two wires in the SV's normal relay that handle the indicators ,makes sense that it should be a 2 pin flasher unit not a 3. My flasher unit has the L & the B pin on. I'm assuming L is live dunno what B is (bu I bet its obvious) and your third pin is earth. This may mean that you could get away with using the 3 pin relay using the L & B pins as normal (wired into the light blue & brown wires on a pointy) then wire the 'E' pin to an earth point somewhere.
Then again I could just be talking bollards....
Old 30-08-09, 03:44 PM   #5
Spiderman
Where the hell am I?
Spiderman's Avatar
TBH i prefer it that my indys flash faster as they get noticed more imo, specially if they are LEDs.
Flash rate for MOT pass is between 90 - 120 per min iirc.
Old 30-08-09, 03:47 PM   #6
Dave20046
Dave20046's Avatar
Mine don't flash at all
Old 30-08-09, 04:07 PM   #7
BomBalong
cheers guys, i was thinking about keeping them flashing fast, but where i work is where VOSA have their weighbridge and scrutineers. so id rather have them legal. plus i cba to sit there trying to count the amount of flashes in a min.
Old 30-08-09, 04:11 PM   #8
Spiderman
Spiderman's Avatar
Dont sit there for a min you nutter, only 15secs and then x by 4. Easy. And you'll find a majority of the LEDs are close enough i think.
Fast movement catches the eye dont you know
FS: Hein Gericke Jacket, lid and Hein Gericke 2 Piece Textile/Leather bigup For Sale - Other Bikes and General biking items 2 22-04-09 01:06 PM
Hein Gericke - Help T0mm0 Idle Banter 30 17-06-08 06:57 PM
problem with flasher relay. fourstrokebeast SV Talk, Tuning & Tweaking 10 30-03-08 07:22 PM
WANTED asap flasher/multi function relay sv650k4 Stuff Wanted 6 24-01-08 09:59 PM
Flasher Relay installation - might have done something bad... R-Razor SV Talk, Tuning & Tweaking 7 07-10-07 12:28 AM
