Old 05-09-09, 08:23 PM   #1
Shanny
Default Help please
I have an SV650S k6 i wonder if anyone could advise how the stock rear fender can be removed to make way for a tail tidy?
Old 05-09-09, 08:39 PM   #2
Brettus
Default Re: Help please
I found some instructions online for hamicad one I think it was, when I did mine. Worked a treat.
The tail tidy I had was an evotech but its all the same difference.
Basic jist is, side panels off, seat off, seperate the rear fairing halves and 4 push studs on the underside and slip that off.
From there its just 2-4 bolts I think, I only remember 2 but 4 seems logical thinking back.
the only bit I had to watch out for was slotting the undertray in right with the tail tidy.
Old 05-09-09, 08:57 PM   #3
Brettus
http://www.hamicad.co.uk/SV_Fender.html
The instructions are linked off that page, although it doesn't seem to work in firefox but displays fine in IE. PDf file, print it off and take it outside with you as you do it. that method worked for me anyway
HTH
Old 05-09-09, 09:05 PM   #4
fastdruid
fastdruid's Avatar
9 inch angle grinder and a cutting disc.
Druid
