Old 14-09-09, 11:36 AM   #1
robh539
Default knocking forks. what causes this?
hi all, i have a knocking fork issue and play when the front brake is on. I sstarted looking at it as i thought it was the head set brearing. Altough have a few min's playing dicovered the play is from the forks and can hear / feel moving at the bottom of the forks.
what is the cause of this? its a curvey with 22 thou on the clock.
thanks to your help as always
Rob
Old 14-09-09, 11:53 AM   #2
Default Re: knocking forks. what causes this?
The fork bushings if you are certain the play is not from the headstock.
Old 14-09-09, 02:17 PM   #3
robh539
ok thx yorkie
I thought as much. deffo not the headstock, time for uprated springs as well then.
Old 14-09-09, 02:32 PM   #4
Seals, anti friction bushes, oil. Might as well do the springs while you're there.
Knocking Phaelok Bikes - Talk & Issues 6 28-12-08 05:51 PM
knocking??? guzz316 SV Talk, Tuning & Tweaking 9 18-09-08 12:51 PM
Knocking noise Cam_73 SV Talk, Tuning & Tweaking 3 04-08-08 07:48 PM
Need help! Bikes knocking somewhere? Rickstar SV Talk, Tuning & Tweaking 11 29-06-08 07:07 PM
Can you guess the knocking on my SV? Grinch SV Talk, Tuning & Tweaking 13 22-05-05 12:05 AM
