Old 22-09-09, 08:06 PM   #1
madness
Default Feeling sorry for myself!
I've been to the dentist today and he's told me that I'm going to need to have my two upper front teeth taken out, and probably one next to them as well.
Basically they've been dead for 30 years and have been crowned. I had an infection in the roots of them about 15 years ago and had to have an operation to remove the apex if the roots.
I've had the infection come back recently and it's not responded to anti-biotics. I've persuaded him to give me more anti-biotics, but he says they won't work.
So, I've now got to consider my options
1) Be front toothless - Free
2) Wear a denture - About £100
3) Have a bridge - About £500
4) Have implants - About £3600
I know that this is a miniscule problem compared with a lot of peoples problems, but I'm thoroughly p***ed off about it.
Old 22-09-09, 08:08 PM   #2
Dave20046
Dave20046's Avatar
Default Re: Feeling sorry for myself!
**** mate, had a nightmare last night 2 of my molers fell out I was gutted. bad luck
Old 22-09-09, 08:11 PM   #3
My dad is in a similar situation. He keeps getting really sore abscesses and having to get teeth removed. Luckily not his front ones like you.
Is the implant where they bolt a fake tooth to your jaw?
Old 22-09-09, 08:13 PM   #4
tonyk
tonyk's Avatar
would it be cheeper in euroupe ?
"Meh" - ASM Forever, RIP. 13/03/1986 - 05/04/2008
"Better to keep your mouth shut and appear stupid than to open it and clear all doubts."
Some days its not even worth chewing through the restraints...
tonyk is offline   Reply With Quote
Old 22-09-09, 08:14 PM   #5
madness
Out of the options, the tootless one is a no no to start with. I don't want a denture, I'm only 43! The bridge will mean basically killing two perfectly healthy teeth that will then have a limited life. Finally for the money that the implants would cost I could have a brilliant holiday or buy myself a gixer/whatever
Old 22-09-09, 08:16 PM   #6
timwilky
timwilky's Avatar
I know at least one of my upper front has to come out as the root filling is failing. Denture is a no no, the one next to it is effectively dead with a veneer fitted to disguise the colour that that would probably go at the same time.
I guess a foreign holiday for implant work may be in order.
Not Grumpy, opinionated.
Old 22-09-09, 08:17 PM   #7
Ed
If I were you I'd go get a second opinion.
Old 22-09-09, 08:18 PM   #8
madness
Yep, they screw titanium inserts into your jaw bone and the fix false teeth to them. It's all done under local anesthetic and takes between 6 and 9 months from removal of teeth to the finished product. Been shown some pictures and it looks gruesome!
Old 22-09-09, 08:18 PM   #9
Wideboy
Evel Knievel
Wideboy's Avatar
i've got a front tooth crowned as it was broken, the tooth has been drilled out and capped but the real tooth is now fragile and comes loose if suffers a knock
that cost me 500 smackers
Old 22-09-09, 08:20 PM   #10
anna
anna's Avatar
I had teeth problems when I lived in London, they have a detist school hospital though and any sorts of problems can get fixed for free. They are carried out by people not yet graduated however they are all in their final years, and have supervision at all times.
I dont know if they might be able to help you.
Do you ever get that feeling you're being followed? Caddy2000 The Essex Lounge 6 20-08-09 02:04 PM
Feeling sorry for myself! madness Idle Banter 4 09-03-09 05:38 PM
Im feeling so down... ThEGr33k Idle Banter 62 02-12-08 02:47 PM
I'm feeling...... Scoobs Idle Banter 31 30-04-08 10:53 AM
Feeling a bit c**p Alpinestarhero Soho Massive 44 09-12-07 05:14 PM
