Old 24-09-09, 04:41 PM   #1
Cairo
Default Rectifying false neutrals
I don't understand enough about the inner workings of engines and gearboxes so:
After I've got a false neutral I dip the clutch and change into gear with no throttle and an almighty clunk. Would blipping the throttle first help make the process smoother or would it make it worse and possibly knacker the gearbox. The chain is correctly adjusted and I accept that false neutrals happen and they're not happening often enough to be a major concern.
Old 24-09-09, 04:49 PM   #2
wattyfred89
wattyfred89's Avatar
Default Re: Rectifying false neutrals
Yep thats what i do. My pointy has always had false neutrals if you let it. Happens Rarely now though, gta change gears like a Man!
wattyfred89 is offline   Reply With Quote
Old 24-09-09, 05:00 PM   #3
jambo
jambo's Avatar
make sure your gear lever is at the right level, if it's a little high or low (more commonly too high) the number of false neutrals goes up.
Also if you hit a false neutral try to go up a gear to get out rather than down.
Jambo.
Old 24-09-09, 05:10 PM   #4
fastdruid
fastdruid's Avatar
I also found if the pivot was gunged up it would make things worse.
Druid
Old 24-09-09, 05:32 PM   #5
Cairo
Thanks everyone.
wattyfred89: Change gears like a man? Do you mean being a bit more forceful with my gear foot?
jambo: My gear lever is set as high as it will possibly go so I'll try adjusting it down a little and see how it goes.
fastdruid: Thanks, I'd not thought to have a close look at the pivot so I'll do that.
Like I said it's not really a major issue as it only seems to happen once every 100 or 200 miles or so. I'm more worried about preserving the gearbox on the occasions it does happen.
Old 24-09-09, 05:34 PM   #6
vardypeeps
Another tip you could pull the clutch and brake right down untill you have stopped almost then put it in first and start again
That's what I tend to do
Old 24-09-09, 05:44 PM   #7
wattyfred89
Originally Posted by Cairo View Post
Thanks everyone.
yes basically, not ruff but firm ... i tend to get them when i ride wearing my Doctor Martin's as they are less thick than motorbike boots, so when shifting up a bigger movement with the foot is needed as the lever is further away (easy to adjust) .
Old 24-09-09, 05:53 PM   #8
sinbad
I had a LOT more false neutrals when I was running Castrol performance bike specific 10w40 oil than I have done since switching to the same grade Hein Gericke cheap-but-okay stuff.
Old 24-09-09, 06:13 PM   #9
Alpinestarhero
Sinbad:
I use castrol oil, Semi synth 10w40. I encounter no problems.
Falsie neutrals can also stem from incorrect chain tension (I found I got a few when my chain was a little tight)
Jambo, why go up rather than down?
Old 24-09-09, 06:22 PM   #10
Less of a crunch!
False Neutrals Grant66 SV Talk, Tuning & Tweaking 5 22-01-09 12:48 PM
False Neutrals Smudge Bikes - Talk & Issues 11 31-01-08 07:06 PM
False Neutrals? rob13 SV Talk, Tuning & Tweaking 18 03-09-07 12:10 PM
False Neutrals Jogrsyu Bikes - Talk & Issues 21 27-03-07 01:54 PM
False neutrals Fuzz SV Talk, Tuning & Tweaking 18 23-08-05 11:46 PM
