Old 29-09-09, 08:02 AM   #1
hindle8907
hindle8907's Avatar
Default Head Light Clamp (GSXR)-Sv650N
Got all the bits for my GSXR converstion on my naked SV650 just need the headlight clamps but i wanted to keep the little meter cover thingy you know what covers the clocks and goes round on top of the head light
But its the headlight brackets that hold this in place has anyone done a gsxr conversion with a naked and kept this in place if so can you tell me how Cheers ant.
Old 29-09-09, 05:51 PM   #2
Default Re: Head Light Clamp (GSXR)-Sv650N
On the GSXR-front-end-on-a-naked that I assisted with the original headlamp brackets were used after some modification. The rings were split open and the original rubbers re-used, (albeit that it's quite a squeeze), on the new forks. Obviously the yokes aren't the same distance apart, so the brackets needed to be shortened and rewelded at the right length.
Check where the fairing needs to be and shorten at the appropriate end.
Old 29-09-09, 06:43 PM   #3
hindle8907
hindle8907's Avatar
cheers sid that is what i was thinking,.... about cutting the brackets but dont understand why they would need welding once cut as they would just fit right on and everything should pop on .
Old 01-10-09, 08:50 PM   #4
The ones I did required shortening as the GSXR clip-ons were used, as the clip-ons fit underneath the top yoke the brackets needed to be shortened to accommodate that.
Old 01-10-09, 09:10 PM   #5
hindle8907
hindle8907's Avatar
O rite .. yeah i get what you mean .
Im doing naked with Bars so ill be ok then cheers for your help .
Old 01-10-09, 10:41 PM   #6
Possibly, I don't know if the GSXR yokes are the same distance apart as the SV ones, I'm sure there's not a huge difference though.
What top yoke are you using, and what are you doing for a speedo drive?
Old 01-10-09, 10:56 PM   #7
For top yoke I will cut alloy plate to fit in voids underneath yoke, drill to suit risers and bond in with epoxy. (don't want to TIG it for fear of distortion and causing stresses).
Another alloy plate held on with same bolt as risers coming forward to hold clocks on original mounts.
Edit: it is stock top yoke from GSXR600K1-3
Speedo sensor will be magnets and 1GT101DC hall effect pickup.
Old 02-10-09, 07:55 AM   #8
hindle8907
hindle8907's Avatar
what YC said lol
99-2002 head light 99-2002love Stuff Wanted 5 05-03-09 11:38 AM
head light getting brighter larigos SV Talk, Tuning & Tweaking 1 18-01-09 02:10 PM
SV650N Front End in Good Condition, leftovers from GSXR Swap Ter For Sale - SV's and SV related items 3 07-05-06 02:03 PM
head light bulb jamieclayton9 SV Talk, Tuning & Tweaking 1 13-07-05 04:23 PM
head light adjustment bluesvrider SV Talk, Tuning & Tweaking 0 22-03-05 04:06 PM
