Old 04-10-09, 01:46 PM   #1
cF^
Default Bolt size and brake query
I'm giving the bike a clean today after mammoth ride yesterday and notice i'm missing a bolt. Does anyone know what size bolt is required for this ere hole? I can't take out the other one slightly further up the swingarm as i've not got a spanner that'll fit in such a tiny space.
Secondly, upon giving my brakes a quick clean and a once over I notice this ->
Can anyone tell me what's happened here? I've moved the little white bit out further than it was but it looks like something inside the brake has snapped. Do I need a new something? If so, what?!
Cheers for any help, i'm hoping i've got time to ninja down to B+Q to fix the problem today!
Old 04-10-09, 01:54 PM   #2
fastdruid
fastdruid's Avatar
Default Re: Bolt size and brake query
M6x15 IIRC
Brake pad heat resistant backing, as long as it won't come out don't worry about it, if it will then get new brake pads.
Druid
Old 04-10-09, 01:55 PM   #3
cF^
legend! off to b+q I go!
Old 04-10-09, 02:27 PM   #4
cF^
That did the trick, thnx! As an aside, any idea where one can purchase those brake tube routing clip things? Mine are looking quite tired, bet they don't cost much to replace!
Old 04-10-09, 02:32 PM   #5
Nicky S
Nicky S's Avatar
i cant rember what they are called but demon tweaks and m&p do them just to name a couple
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 04-10-09, 04:56 PM   #6
fastdruid
fastdruid's Avatar
P clips
Druid
Old 04-10-09, 05:16 PM   #7
xXBADGERXx
If you want the official Suzuki ones for the Pointy then here are the part numbers and prices .
FR Right Hand Side clip : 59264-17G00 £3.51
FR Left Hand Side clip : 59268-17G00 No match found on price
Rear Guide : 69260-16G00 £11
The Rear Brake Pad Insulator is : 69132-06G00 £10.99 (per side)
Old 04-10-09, 05:20 PM   #8
cF^
wow what service, thanks!
If I buy new brake pads will those insulators come with it? Seems like quite alot of money for what appears to be a white sliver of cardboard =p
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
Front brake hose splitter securing bolt size? Tim in Belgium SV Talk, Tuning & Tweaking 5 12-06-07 07:53 PM
Help with bolt size TC3 SV Talk, Tuning & Tweaking 2 20-03-07 06:28 AM
HELP Bolt Size ... sprocket SV Talk, Tuning & Tweaking 2 02-07-05 08:11 PM
bolt size please Quiff Wichard SV Talk, Tuning & Tweaking 17 20-05-05 09:03 AM
