Old 06-10-09, 05:36 PM   #1
Triv650
Default Fuel Injection or Carburetor?
Dunno if this has been asked before (I've searched) but in your mind, which is better and what are the main differences?
Old 06-10-09, 05:46 PM   #2
philbut
Default Re: Fuel Injection or Carburetor?
Depends if you like pointy or curvy bike
In general FI is easier to look after as you don't need to clean / rebuild carbs periodically. Having said that, carbs aren't really that bad if you know what you are doing. People always bang on about carb icing being an issue, but I've never had too may problems. you can stick a bit of additive in the tank (or white spirit) if you ride in cold damp conditions. i just keep the carb heaters in good order and have never needed to.
On the flip side, carbs tend to give a smoother throttle response, or did do - modern FI has probably come on a long way sice the 03 bike that I rode. I didn't like the throttle response at all coming from a silky smooth carbed bike. I have 3 bikes, all with carbs and don't really want to go down the FI route yet.
EDIT - so to answer your question, neither is "better" as such. they both have advantages. FI is better for the environment as it can run leaner than a carburetor (carbs as a compromise essentailly), so less unburnt hydrocarbon is chucked out the back.
Old 06-10-09, 06:16 PM   #3
captainsmelly
Carb'd SV's are not ugly, injected ones are.
I've always thought that injection systems have far mare to go wrong, more expensively, than carby jobbies.
And on a massive derail, philbut really can you use white spirit? I dont know why not, but I dont know why either
Old 06-10-09, 06:22 PM   #4
philbut
So I believe. I've never tried it mind - never needed to. I think if you look at a bottle of Silkoline FST or similar, the main ingredient is alcohol based. i don't know the quantity you need however, but I guess similar to that of any similar branded additive.
Old 06-10-09, 10:16 PM   #5
It's isopropanol. You can use that alone to stop carb icing, way cheaper than pro FST.
I like carbs, you can fix if they go wrong.
Old 07-10-09, 02:31 AM   #6
lukemillar
You can fix FI as well
Old 07-10-09, 07:27 AM   #7
wow
You asked for main differences.
With FI the engine gets exactly the right amount of fuel. so when waming up it idles a bit lower and then adjusts itself. It's all automatic.
With carbs you have to do this by hand by keep on pushing the choke in. Gives you more of a bond with your bike tho. Don't know if you have to turn the fuel tap off every day on an SV but that's another difference.
FI is better for the environment. Emission requirements have led to all new bikes being FI nowadays, only v recently tho.
Old 07-10-09, 07:59 AM   #8
philbut
SV has a vaccum operated fuel tap, so no. TBH, I never turn my fuel taps off on my bikes unles the tank is coming off.
Old 07-10-09, 08:20 AM   #9
With much more faffing about. Ever tried to find a broken wire in an FI loom?
Bah. Screw the environment, get some snorting great carbs big enough to loose a child down!
Old 07-10-09, 09:13 AM   #10
GavinD
having had both I would go with FI every time - its smoother to ride in my experience and more reponsive in throttle on/off in the high revs e.g similar speed corners that require holding the same gear.
Fuel Injection Light mayang SV Talk, Tuning & Tweaking 0 24-07-06 07:23 PM
fuel injection issue w1ll15 SV Talk, Tuning & Tweaking 5 18-07-06 05:02 PM
K6 Fuel injection Baph SV Talk, Tuning & Tweaking 4 12-07-06 10:41 AM
Is it possible to flood Fuel Injection? Scoobs Bikes - Talk & Issues 23 12-12-05 06:31 PM
Fuel Injection... steveo SV Talk, Tuning & Tweaking 6 23-11-04 01:43 PM
