Changed oil @ filter today replaced sump plug washer , was not sure if it mattered what way up you fitted the washer ? washer has got a flat side and a angled side which is soft and crushes , is they a right way or does it not matter ?
Cheers Steveg
ex - red sv650s 06 reg Now Triumph sprint 1050 ABS 05 Reg AKA Papa Smurf ![]() |
If it don't leak don't bother. I usually out the flattest side up against the engine. They cost like 20p so not an expense to replace or you can probably anneal(spelling?) them if it ain't sealing right.
If by "angled side" you mean a chamfer on the hole through the sealing washer, it is to clear the neck of the plug, and should be placed on the plug side.
If that is not what you are referring to - pass, no idea!!
SV1000S K4, Hugger, Scottoiler. Lowers |
Nothing wrong with re-using, given the washer isnt too warped.
I like to wrap some PTFE tape around the head of the sump bolt and over the washer to make an extra sealed seal ![]() |
Look at spark plug next time, it is same type washer and goes same way, flat against bolt head.
stick it on anyhow it crushes flat anyway, i just use the old one never had any leaks.
#7 | |
Isn't it a dowty washer? Usually what gets used on sump plugs.
Sump washer | TightRS | SV Talk, Tuning & Tweaking | 3 | 18-04-09 09:56 PM |
Sump plug washer - where from? | pencil shavings | SV Talk, Tuning & Tweaking | 26 | 17-03-09 08:52 PM |
Sump plug washer | yorkie_chris | SV Talk, Tuning & Tweaking | 3 | 29-09-07 10:44 AM |
oil sump bolt washer | lukemillar | SV Talk, Tuning & Tweaking | 8 | 13-09-06 10:22 PM |
Sump washer | The Mass | SV Talk, Tuning & Tweaking | 14 | 27-06-06 09:53 AM |
