Old 22-10-09, 04:11 PM   #1
Nick8529
Default running problem - as if running out of petrol
Hi,
I have been having a bit of problem with my bike. It has been running with really low revs an is really jerky as if it is running out of petrol but there is plenty petrol in. The engine sounds really rough and is shaking alot. I had to have the throttle open quite far and every so often it will suddenly go back to normal and because i had the throttle open far it would suddenly shoot off. Then the revs would drop back down again and would die if i didnt keep the revs up.
I have got no idea what is wrong. at first i thought it could be out of oil but there is loads of oil. When this happened it was raining quite heavily so i thought that might have something to do with it but it is dry now and it still has the problem.
Thats all my ideas so if anyone could tell me what the problem could be and if i can fix it fairly simply as i dont have much knowledge about bikes that would be great!
Old 22-10-09, 04:16 PM   #2
starks
Default Re: running problem - as if running out of petrol
im having a similar problem at the mo pal, dont know wat it is yet sorry but when i find out i'll be able to give you a heads up to what it could possibly be
Old 22-10-09, 04:16 PM   #3
monkimagic
sounds like a trapped vaccum hose, have you had the tank off or poked about under there lately.
or a fuel feed problem
or
Old 22-10-09, 04:19 PM   #4
Scoobs
....or water in the fuel.
Old 22-10-09, 04:21 PM   #5
Nick8529
I had a look under when the problem started but not for a while before the probelm.
Anything i can do if there is water in the fuel? or am i going to have to run it till its dry and refill it?
Old 22-10-09, 04:30 PM   #6
Make surec that the drain hole under the filler cap is clear so that if it is raining hard water isn't getting into the tank via this blocked drain. Think it's a problem on some curvy's.
Make sure its not the front spark plug getting wet either, as mine was a bit like this before in the wet. Cured with a fenda extender & a bit of silcon grease round the front plug cap. WD40 on the spark plug & make sure the drain on the front cyclinder is clear as well, otherwise the water can't get out
And you could check to make sure that all the vacum & petrol pipes haven't perished and letting a tiny amount of air in somewhere. I had a car do this to me once
Do the spark plug first, as this is a common problem on Sv's in the wet for some, but not all
Old 22-10-09, 04:35 PM   #7
Nick8529
If it was the spark plug would it not work fine when it was dry?
Old 22-10-09, 04:38 PM   #8
Wet front plug I reckon.
Water takes a while to dissipate.
Old 22-10-09, 04:39 PM   #9
Not if the drain hole is blocked and the spark plug is still damp. Mine took ages to get back to normal, even though I'd sprayed loads of WD on the plug cap & spark plug
Old 22-10-09, 04:39 PM   #10
Thanks YC +1
sv running problem? any ideas Crunchy SV Talk, Tuning & Tweaking 6 31-07-09 04:27 PM
Not Starting after running out of petrol. gerbrox Bikes - Talk & Issues 4 15-08-08 10:52 AM
And you thought running out of oil was a problem... gettin2dizzy Idle Banter 22 11-06-08 08:04 PM
Odd choke/running problem northwind SV Talk, Tuning & Tweaking 13 07-06-05 11:46 AM
Starting /rough running problem Sholay SV Talk, Tuning & Tweaking 5 26-01-05 04:18 PM
