Old 27-10-09, 09:43 AM   #1
Lucas
Default Brake piston removal
These are curvy front brake, it has been taken off for rebuild.
I'm wondering how the pistons can be removed without expensive special tools.
cheers,
Lucas
Old 27-10-09, 09:50 AM   #2
martianskippy
Default Re: Brake piston removal
cheers,
Lucas
Connect them back to the brake hose and squeeze the brake lever until they pop out ? ...
Alternatively connect the brake calliper to an air compressor and let the pressure do the work for you
Old 27-10-09, 09:54 AM   #3
Lucas
cheers, but I don't have a compressor.
Old 27-10-09, 09:57 AM   #4
plowsie
I tend to use a thick rag or T-shirt folded over a few times (so to not score the piston at all) and clamp and pull with a set of Mole grips.
There is probably a better safer way than this though. I know nothing.
Old 27-10-09, 10:02 AM   #5
Bunks
I did it like this on my gsxr calipers but was careful. I'm sure it's not the proper way to do it but no harm was caused.
Nick
Old 27-10-09, 10:05 AM   #6
These aren't too expensive are they?
http://cgi.ebay.co.uk/Motorcycle-Bra...item25557c88a3
Old 27-10-09, 10:21 AM   #7
punyXpress
punyXpress's Avatar
+ 1 the first line of martianskippy's reply, but DON'T use air!
If the piston is really stuck, when it finally lets go under air pressure it will literally be a missile. Hydraulic is far safer.
Now: Street Triple R
Old 27-10-09, 10:26 AM   #8
Lucas
seems good, it's the first time I believe the claim of 'added pulling power'
£18 is not a lot, but it'll be a tool used once in a few years if that...
i'll give the mole grips a careful try first.
thanks everyone for the tips.
lucas
Old 27-10-09, 12:26 PM   #9
martianskippy
Nick
I would be afraid that the piston could get deformed this way, even though no scouring can be observed..
I think using the hydraulic pressure of your brake system is the safest and easiest way forward - you don't need any additional tools and you can be 100% sure you don't damage the piston in any way.
Anyways, I know nothing so please feel free to disregard my posts in this thread
Old 27-10-09, 12:51 PM   #10
Dave20046
Dave20046's Avatar
Both the molegrips & compressor ways are a bit risky, I had to do this on friday night and just did it the hydrolic way.
The tools unnecesary unless you rebuild calipers that aren't attached to a bike often. Takes literally 10 minutes to put the calipers on a bike, bleed up and pop out.
Can't stop a front brake piston from leaking Heather SV Talk, Tuning & Tweaking 11 31-03-09 10:31 AM
Seized brake piston? xlewdx SV Talk, Tuning & Tweaking 13 13-11-06 09:49 AM
Rear Brake Pedal Removal??? MarkyBoy SV Talk, Tuning & Tweaking 6 12-08-05 02:15 PM
Help! Brake piston problem HKP SV Talk, Tuning & Tweaking 8 24-05-05 12:51 PM
2000 SV650S Rear Brake Piston Seal Tris SV Talk, Tuning & Tweaking 5 29-12-04 09:04 PM
