Old 31-10-09, 09:35 AM   #1
boot
Default Valve cover gaskets
Thinking about doing my valve clearances today...
I don't have replacement gaskets though. Now, for anywhere where keeping fluid in is important, I'd replace gaskets, but, is it really worth replacing them for the valve covers, or just re-use.
Old 31-10-09, 09:49 AM   #2
PaulSV
Default Re: Valve cover gaskets
I thought about mine too, then sent it off to the dealer 'coz I'm lazy
Old 31-10-09, 10:02 AM   #3
Had the covers off my motor probably 8 times and still on same gaskets. They're not a paper type that rips they're a rubber one.
Old 31-10-09, 11:31 AM   #4
boot
Great, cheers Chris!
Started on front caliper overhaul for now, chewed screw in the reservoir. Luckily, had extractor set I bought ages ago that I've never used until now.
Old 31-10-09, 11:37 AM   #5
boot
Can't afford to, the reward for doing the job myself is great, and wouldn't trust a dealer anyway - how would I know if they didn't need adjusting and was told they would, then get billed for checking them and again for changing the shims.
Only thing is, don't have tensioner tool if I do need to change them, but it's a cheap job, and although I've not done it before, HBL reckons it's easier than this mornings job.
Old 31-10-09, 12:19 PM   #6
You can make tensioner tool in 5 minutes, chop up a hacksaw blade.
Old 31-10-09, 04:15 PM   #7
Dave20046
Dave20046's Avatar
If yours are in a real mess I have a spare you can have, can't guarantee it's performance either though.
Old 31-10-09, 11:52 PM   #8
beabert
+1
Old 01-11-09, 01:11 PM   #9
boot
Cheers mate!
Didn't do it in the end, did both callipers then took the little-un to the park, weather's too pants to do it today, maybe next weekend!
Fitting new cylinder head cover gaskets flymo SV Talk, Tuning & Tweaking 12 05-10-10 08:48 AM
Clutch / generator cover gaskets lazymanc SV Talk, Tuning & Tweaking 5 21-06-09 06:46 PM
Leaking rocker cover gaskets flymo SV Talk, Tuning & Tweaking 5 18-03-09 11:38 AM
Valve cover leaking? dareme97 SV Talk, Tuning & Tweaking 8 08-04-08 04:39 PM
Valve Clearances, Alternator Cover woes and a Paint Job Blue Flame SV Ecosse 31 05-04-08 05:16 PM
