Old 09-11-09, 12:41 PM   #1
madness
Default Recommend me a free Boot Loader program
Can anyone recommend me a good free boot loader program for my PC.
I have just installed a second hardrive into my PC and have loaded Ubuntu onto it. I need something that will allow me to boot from my original hard drive (Vista) or the new one. Obviously I can set my Bios to whichever I want but that's a faff every time I turn the PC on. I just want something to give me the option when I turn on. Is it a boot loader program I need?
Old 09-11-09, 12:56 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Recommend me a free Boot Loader program
Erm GRUB that comes with Ubuntu will do that for you...
Old 09-11-09, 01:16 PM   #3
cmsd2
install grub inside the bootable partition of the second disk, and get the nt bootloader to chainload grub?
Old 09-11-09, 02:03 PM   #4
madness
Soulkiss -I'll have a look at Ubuntu tonight
cmsd2 - I'm not that clever!
Old 09-11-09, 03:24 PM   #5
SoulKiss
SoulKiss's Avatar
I have never dualbooted a Linux/Windows combo - always had enough spare hardware to not need to...
So with that in mind, set the machine to boot into Ubuntu, then open a terminal and run
dpkg-reconfigure grub
This will (I believe) cause GRUB to rescan for OS's and set itself up as the Bootloader, and hence present you with the option of which OS after a reboot.
At least thats my understanding, having never done it before.
This advice COULD result in data loss, but is probably a good place to start from.
Old 09-11-09, 08:58 PM   #6
rick0361
When I installed Linux last time it installed Grub for me and I then had a boot choice from Windows or Linux then from Wondows either XP or 98
Just be wary that if XP SNAFU's and you have to either reinstall or do a reformat of the MBR you will lose Grub and be faced with either reinstalling or reconfguring the Grub loader to get it back again.
Have you considered VM'ing the other OS on the PC using something like Virtual PC?
Old 09-11-09, 09:57 PM   #7
boot
Tools in XP allow easy fixing of the boot record. Can't remember off the top of my head, as it's many years since I've had to use them. However IIRC, I think FIXMBR (fix master boot record), FIXBOOT (writes new partition table info?) and BOOTMGR (allows editing of which partition will boot), accessible form the recovery console, are the tools I used to repair. Especially if you get NTLDR.EXE is missing error.
No idea if this is the same for Vista though, so may not be of any use whatsoever.
911 TV program suzsv650 Idle Banter 88 10-09-09 10:42 AM
recommend me a free ppt to pdf convertor... Paul the 6th Idle Banter 5 17-06-09 09:10 AM
Recommend me a newsletter program. pben47 Idle Banter 2 03-11-08 06:44 PM
TT Program on ITV4 now pmapp Idle Banter 0 29-05-08 04:02 PM
any one recommend a cheap water proof boot? steveg Boots 9 20-10-06 11:18 PM
