Old 09-11-09, 05:52 PM   #1
jimmyb96
Default adjusting pre load rear
hi all,
can someone tell me if adjusting the preload on rear suspension on 07 sv650s k7 is a big job as my tip toe only touch ground and i need it lower to have more control ?
cheers guys
Old 09-11-09, 06:22 PM   #2
timwilky
timwilky's Avatar
Default Re: adjusting pre load rear
You need to lower the bike height , not alter the suspension pre-load setting.
change your dog bones
Not Grumpy, opinionated.
Old 09-11-09, 06:25 PM   #3
Bluefish
as tim sais, altering the preload, does not alter the height of the bike, only the ammount the suspension moves.
Old 09-11-09, 06:45 PM   #4
BoltonSte
the bar labelled A on this.
http://attach.kawiforums.com/2006/05...733-0-7360.jpg
Longer ones lower the bike, shorter ones raise it.
Sorry if you know already, but thought it'd help. (do a search on here to see what size you need)
Ste
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 09-11-09, 07:29 PM   #5
Preload might help a bit, but it's a bodge.
Old 09-11-09, 07:53 PM   #6
Good advice from everyone there - assuming the preload is correct presently.
If not, then there may be some lowering of the bike when it's set right.
Adjusting a Curvy Hagon Rear Shock TheStudent SV Talk, Tuning & Tweaking 7 22-06-09 08:44 AM
adjusting Hagon rear shock on bike.....? etuna SV Talk, Tuning & Tweaking 7 21-03-09 08:32 PM
Adjusting Rear Suspension on SV Stoneyginger SV Talk, Tuning & Tweaking 5 27-04-08 06:29 PM
Rear Shock Hydraulic Pre-load Adjusters Luckypants SV Talk, Tuning & Tweaking 5 31-01-07 05:02 PM
Adjusting rear suspension Chris1 SV Talk, Tuning & Tweaking 8 22-03-05 12:26 PM
