Old 23-11-09, 02:55 PM   #1
widget
Default spring rate calculation
had a look around and on racetech but still confused.
im looking to get a gsxr shock but need to work out what spring to go for im 85kg with my kit on.
also trying to find other sizes for shocks i.e k6 7? i think it was the k7 that had the frame change so the shock is shorter
any ideas?
Old 23-11-09, 02:58 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: spring rate calculation
If you change the spring on a gsxr shock to what it should be for an SV your damping will be way off, I did it but to a Penske shock and there was litraly 0 rebound dampingeven when it was cranked up, so i had to get it revalved
im not sure if its as bad on a pointy as it was on a curvey though
Old 23-11-09, 03:43 PM   #3
widget
hmm am i best off trying to match a gsxr shock to the sv then and leave it with that spring on?
i dont want to change dogbones and mess with the 2-1 ratio
Spring Rate and Oil Weight? PURPLE SV Talk, Tuning & Tweaking 4 25-05-09 07:43 PM
Can anyone rate this HG kit? sauluk Bikes - Talk & Issues 36 05-11-08 11:36 PM
Which spring rate for a chunky rider? Biker_Billy SV Talk, Tuning & Tweaking 11 04-02-08 12:27 PM
How do you rate yourself? gettin2dizzy Idle Banter 6 27-11-07 02:33 PM
MCN: Rate my too......go on, go on, go on scarlett Bikes - Talk & Issues 30 11-08-07 10:37 AM
