Old 26-11-09, 12:14 PM   #1
The Guru
Default Monitoring Internet Usage
Some of the guys that I work with have been told to lay off the internet as they are using it to much.
Is there away around being monitored?? or are we all screwed?
Old 26-11-09, 12:18 PM   #2
Sally
Default Re: Monitoring Internet Usage
Do some work.
Lunch time and breaks are for internet use.
Old 26-11-09, 12:19 PM   #3
jambo
jambo's Avatar
There's almost always a round these sorts of things, but without knowing how they're measuring your internet usage at the moment it's a bit hard to tell what you'd want to be hiding.
Jambo
Old 26-11-09, 12:27 PM   #4
TheOnlyNemesis
set up a sly virtual machine
Old 26-11-09, 12:28 PM   #5
The Guru
Do some work.
I'll keep that in mind.. we shall call that 'Plan Z'
Old 26-11-09, 12:29 PM   #6
The Guru
For example connect remotely to home PC and surf via that??
Please explain.
Old 26-11-09, 12:45 PM   #7
AndyBrad
im interested in this as were monitored through a proxy. would be interesting if you could get round it
Old 26-11-09, 12:50 PM   #8
-Ralph-
You need to know the infrastructure that is in place and what they are reporting on guys.
Old 26-11-09, 01:03 PM   #9
TheOnlyNemesis
Please explain.
download a piece of software any u can find that sets up virtual machines and basically you run a machine inside your machine vistually they won't be able to monitor what you do in the virtual machine
Old 26-11-09, 01:06 PM   #10
ophic
ophic's Avatar
They can monitor network traffic. So unless you want the vm to just sit there and be all secret, and not connect to anything, then umm... won't work.
Silver SV650SK3, Fuel exhaust
oil usage? AndyBrad SV Talk, Tuning & Tweaking 7 28-07-09 09:51 AM
Internet monitoring embee Idle Banter 8 18-03-08 08:44 PM
Got new internet security, and now internet is sooo slow neio79 Idle Banter 9 19-07-07 10:54 AM
pc help - ram usage strange Warren Idle Banter 11 02-07-07 01:39 PM
Oil usage timwilky SV Talk, Tuning & Tweaking 8 12-07-05 02:25 AM
