Old 28-11-09, 10:16 PM   #1
5hort5
Default Moving forward with the clutch in.
I noticed today whilst testing after fixing my little running problem that if the bike is in first and I rev the engine to say 3k rpm it creeps forward, revving it higher it creeps forward faster. Is this a badly adjusted cable or a sign of something else?
Many Thanks
5hort5 is offline   Reply With Quote
Old 28-11-09, 10:33 PM   #2
svrich
Default Re: Moving forward with the clutch in
I had almost the same on mine soon after I got it and it was difficult to get neutral too. All that was needed was the clutch adjusting. But you could also change the oil if it hasn't been done for a while.
Old 28-11-09, 10:36 PM   #3
5hort5
The oil is brand new rich so that's ok, then you say adjust the clutch do you mean the cable or is there some other adjustment/
TA
Old 28-11-09, 10:41 PM   #4
svrich
Mine was in on warranty but they told me the cable was adjusted and that sorted it.
Old 28-11-09, 10:45 PM   #5
ArtyLady
Has it got a lot of play on the lever that you can take up? (ps hubby told me that - I don't know anything about bikes !)
Old 28-11-09, 11:15 PM   #6
Default Re: Moving forward with the clutch in.
First adjust the clutch - not just the cable.
Originally Posted by Me!
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod, back it out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
Old 28-11-09, 11:15 PM   #7
5hort5
A little bit, maybe 1 cm but that could be just the wobble in the lever
Old 28-11-09, 11:17 PM   #8
5hort5
Ah, thanks Sid - I will go and give that a go tomorrow if not fishing, looks like rubbish weatehr though so will prob be in the garage
Old 29-11-09, 11:41 AM   #9
Old Git
Old Git's Avatar
Sid, sorry but confuded (easily done with me).
I been out & checked stuff this morning, notice I have similar prob.
On the rear stand, in neutral, if I rev the engine slow spin on the back wheel.
Read the book about adjusting, but seems to be only clutch cable unless I am missing something.
Bear in mind I am newb to this, I have about 15mm 'wiggle' at the lever before any resitance is felt when pulling clutch in, but when 'wiggled' you can see the activation lever moving (a little) down the bottom with the front sprocket cover off.
SHould I have movement down there (ooo er missis), should I have 'wiggle' at the lever, thought this was the freeplay the book was talking about or am I a complete ar$e.
Answers on a postcard please to ........
Old Git is offline   Reply With Quote
Old 29-11-09, 02:31 PM   #10
Old Git
Old Git's Avatar
OK, I am a plank, read it again a couple of times & I get it now, worm drive adjusts at the clutch, not the 'cable' adjuster just above.I am a
Looking forward... ooger Idle Banter 17 08-10-09 11:01 AM
Flash Forward rob13 Idle Banter 9 29-09-09 12:53 PM
Not looking forward to this timwilky Idle Banter 8 07-09-09 04:12 PM
looking forward to weekend Quiff Wichard Soho Massive 27 28-07-09 11:44 PM
is rear caliper 'floating'?? moving axle forward... branny SV Talk, Tuning & Tweaking 4 27-02-06 11:01 AM
