Old 29-11-09, 12:25 AM   #1
DEJA_Vu
Question HID Kits?
Hey guys did a search for any threads but noone seems to have asked about hid kits for sv's. Does anyone know of a company or somebody selling one as I dnt find the standard sv lights very good. Has anyone found a way of boosting them like putting in 75w bulbs or something else?
Thanks
Déjà_vu
Old 29-11-09, 12:31 AM   #2
5hort5
Default Re: HID Kits?
Osram nightbreakers or Philips X-treme Power, I had the phillips and found them great, Taipan posted this link a couple months back:
http://www.powerbulbs.com/blog/index...night-breaker/
Both of these are fine as they wont melt the plastic. HID kits are great but well outta my price range.
Edit, this thread is good: http://forums.sv650.org/showthread.p...highlight=Bulb
5hort5 is offline   Reply With Quote
Old 29-11-09, 11:25 AM   #3
mattSV
mattSV's Avatar
curvy or pointy? The lamps are the same iirc however the lenses on the pointy are very good, especially with nightbreakers. If you still want hids then try www.hids4u.co.uk. Use the code STRATHY to get a good discount
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 29-11-09, 11:32 AM   #4
Holdup
I find them really expensive even with the discount code Hids direct H4 Hi/Lo beam kit 64.99 for either slim or thick ballast and also they are quite cheap on ebay from china, havent bought from Hids direct though but i was looking at that kit for my sv
Old 29-11-09, 06:55 PM   #5
davepreston
amazon sell hid kits for a decent price and ive seen them used i zero visability they were **** hot
Old 29-11-09, 07:13 PM   #6
fizzwheel
fizzwheel's Avatar
It has coome up a few times, but the search function is a little tricky to get the best out of. Heres a few threads that I found that should point you in the right direction
HTH
http://forums.sv650.org/showthread.p...highlight=KIts
http://forums.sv650.org/showthread.p...hlight=HIDDING
Old 29-11-09, 11:07 PM   #7
sv650nutter149
if it helps mate i have a used hid kit twin i just took off my sv looking for 40 quid for it
Old 30-11-09, 12:13 AM   #8
barwel1992
wish the did a kit that would fit the dominators
Old 30-11-09, 01:15 PM   #9
Maybe you could cut the back out of the dominators.
Or run one permanant low beam HID in one side (so there is space in back because no hi/dip solenoid) and one normal H4 main/dip in other side?
Old 30-11-09, 01:43 PM   #10
barwel1992
^ i did think about that both options main problem is on full beem they are to high on low beem they are just right and as normal beam in used most of the time its set up so that the high beem is to high i may look in to it thogh as i would like some stupidly powerful lights to light up all of the road at night and not just a bit.
Lowering kits monkimagic SV Talk, Tuning & Tweaking 1 19-10-09 11:39 AM
Hid kits sv650nutter149 Thames Valley 0 04-08-09 09:38 PM
Hid Kits sv650nutter149 Bikes - Talk & Issues 56 04-08-09 05:09 PM
Bar riser kits nigelv68 SV Talk, Tuning & Tweaking 6 26-10-08 07:57 PM
Jack up kits SVictim TOTALSV Ireland 9 12-04-06 05:36 AM
