Old 01-12-09, 12:07 PM   #1
SUPERSTARDJ01
Default AKRAPOVIC baffle removal?
Anyone know how to remove the baffle from one of these?
Old 01-12-09, 12:24 PM   #2
Sally
Default Re: AKRAPOVIC baffle removal?
Is it held in with a cir-clip?
Or a bolt under the outlet?
Or does it just pull out..?
Have a look for the things above until someone who has one can tell you!
Take a picture too, that will help
Old 01-12-09, 12:26 PM   #3
SUPERSTARDJ01
Ive looked and felt, and it's all smooth, it's a full system.
Old 01-12-09, 01:02 PM   #4
Sally
Mmm well wait and hear from someone who has one and knows what they are talking about
Sorry!
Old 01-12-09, 08:22 PM   #5
muffles
What end can style? Old style has a bolt. If it's the hex style it might be like my Yoshi and have a rubber plug on the side facing the bike, if you remove the plug you can access a hex screw that holds the baffle in.
Old 01-12-09, 08:35 PM   #6
rigor
It may not have a baffle in...
If the exhaust outlet is the full diameter of the "outside" of the exhaust then there is no baffle. If it's smaller then there is a baffle.
Pic of exhaust WITH baffle
The baffle is the bit in the middle. There will be a bolt underneath the outlet, undo the bolt, get a pair of pliers and put the middle bit out. You may want to use a bit of cloth to stop damaging the baffle.
Post a pic of the end of the exhaust and it's easy for someone to tell you if there is one or not.
Old 01-12-09, 10:41 PM   #7
beabert
I used a broom handle to whack it out from inside when a friend first got his lol, well tight. Think we sanded it after so it was less snug (fuel can)
Old 02-12-09, 10:24 AM   #8
SUPERSTARDJ01
I think it doesn't have a baffle then, because there is no centre piece.
Old 02-12-09, 10:43 AM   #9
Mej
thats exactly what mine looks like on the scorpion can, big piece in the middle which just come out after you loosen the bolt
Old 02-12-09, 11:27 AM   #10
SUPERSTARDJ01
Called the place I purchased the bike from to see if they have the baffle which they do not but they said when it needs an MOT take it back and they will pass it as it is. Happy days.
Baffle Removal, does it make your insurance invalid? Mej Bikes - Talk & Issues 34 24-01-10 07:05 PM
Removing a baffle from an akrapovic Zombie Jesus Bikes - Talk & Issues 10 13-02-08 11:15 PM
baffle removal - need help fat_brstd Bikes - Talk & Issues 20 10-01-07 09:48 PM
Stock Baffle removal??? Kilted Ginger Exhausts 6 10-11-06 06:39 PM
Akrapovic Baffle markf SV Talk, Tuning & Tweaking 2 09-01-05 04:19 PM
