Right,
Title of thread may be obscure, but when I removed the lower (aftermarket) fairing from my SV650S I noticed that there was corrosion (melting even) of the right hand fairing on its bottom edge. ![]() Pipes shown: ![]() Probably being stupid here, but what are these for? Help |
As far as I'm aware they're just breather pipes. Didn't think they got that hot. Is it definitely melting?
Breather, but isn't one also the fuel cap drain?
Edit, it is a long time since I had the bits off, so don't quote me
Not Grumpy, opinionated. Last edited by timwilky; 10-12-09 at 01:43 PM. |
Well there is only damage on that side, I personally thought nothing hot came out of those either!
It may have been some nasty chemical spill I picked up on a road, but nowhere else is affected. The damaged plastic has become a gel like consistancy around the affected area. |
I'vegot the same thing.
If it is a fuel breather it may be that the fumes are melting/stripping the paint/plastic. Mine is no where near as bad as that though. I was thinking of replacing the pipes with slightly longer ones so that they are away from the fairing. |
Sounds like a good solution, just point them somewhere more sensible where they won't get blocked.
#7 | |
Cheers guys. |
If you spill anything under the cap it pours down that tube.
I doubt there would be any significant fumes. Druid
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#9 |
Hi SB,
I think Suzuki knew about this, as there is a way to solve this problem, which comes with the Lower Fairings Fitting Kit. It's simply a little square bit of plastic with double-sided tape on it which attaches to the frame (near the brake pedal). The square plastic has a little hook on it to attach a cable tie that holds both those overflow pipes - this re-directs the pipes away from the Lowers. My camera is broken so can't post up a picture, but in the FAQs section of the following site in 'Suzuki Lower Fairing Install Instructions': http://www.suzukisv1000.com/ Page 2 - Section 3 describes what I'm talking about. I love that site (a little less than the Org, mind you!) HTH all the same Chin Last edited by Mr_Chin; 11-12-09 at 06:14 AM. Reason: . |
teh "what you doing this weekend thread"...sponsored by Chesley "Sully" Sullenberger the Third | keithd | Idle Banter | 30 | 18-01-09 11:47 AM |
Curvy lower fairing "air scoops"? | St0rmer66 | SV Talk, Tuning & Tweaking | 1 | 10-01-09 04:24 PM |
Sv650s "1999 to 2000" Lower Fairing | croddman | For Sale - SV's and SV related items | 5 | 11-09-08 08:02 AM |
"Small" slump in productivity today | ooger | Idle Banter | 6 | 15-02-08 06:08 PM |
Lower Fairing "Spare Parts" ***Updated*** | The Wolf | SV Talk, Tuning & Tweaking | 9 | 09-03-05 10:49 AM |
