Old 15-12-09, 11:13 AM   #1
Speedy Claire
Default Help with PDF file
Help needed if possible and many thanks in advance if you can help
I`m trying to edit a PDF file so`s that I can delete some info on the file and be able to type in the blank spaces. Is there anyway I can convert if from PDF format into something I can edit
Old 15-12-09, 11:20 AM   #2
Spiderman
Where the hell am I?
Spiderman's Avatar
Default Re: Help with PDF file
Depends on if you have he full version of Adobe or not Speedy.
I'm assuming not so try this http://www.primopdf.com/index.aspx
i've used it for years, its a good tool.
Old 15-12-09, 11:24 AM   #3
Speedy Claire
Many thanks Spidey... will download and give it a try
Old 15-12-09, 11:27 AM   #4
Spiderman
Spiderman's Avatar
you're welcome Its a good tool.
Old 15-12-09, 11:52 AM   #5
Speedy Claire
Spidey this is going to sound really dumb but now I`ve downloaded the tool how do I upload my PDF file to edit it? I can`t see anything on the tool that says upload or convert etc
Old 15-12-09, 11:55 AM   #6
Spiderman
Spiderman's Avatar
ooo, this is the updated version to what i'm using. I'll have a look and let you know in a bit.
Old 15-12-09, 12:00 PM   #7
Spiderman
Spiderman's Avatar
i think what you need to do is to open the pdf you have, then print it using the primo pdf that will be in your printers now and then you should be able to open the primo version and be able to edit it directly there.
let me know if you cant but i wont be online till later on now as i have to go to the dentist
Old 15-12-09, 12:09 PM   #8
Speedy Claire
Good luck at the dentist.... too much of the cherry chocolate?
I`ll try your suggestion and many thanks again
Old 15-12-09, 12:21 PM   #9
TheOnlyNemesis
if not another good tool is foxit reader
Old 15-12-09, 01:32 PM   #10
Spiderman
Spiderman's Avatar
well personally i think i'm not getting enough of the cherry choc but i;m sure the dentist will hurt me if i say that to him.
So, did it work Claire?
How to delay a batch file in MS Win XP? slloyd Idle Banter 51 05-06-09 12:15 PM
Video file conversion Stingo Idle Banter 7 27-05-09 10:25 AM
Vista file sharing the_lone_wolf Idle Banter 4 26-03-09 09:49 PM
Look what I'm buying (large file, sorry) OF.uk Pennine Massive 12 14-12-04 10:33 PM
