Old 18-12-09, 05:41 PM   #1
ocr_sv
Default regulator/rectifier modifying?
the reg/rec fried the battery on the sv a few weeks back, i've had a little browse on ebay, and the only ones for the curvy are £70 plus, but you can buy them for the pointy for £30,
do they have the same number of wires into them and can i just cut and solder the old terminal onto the newer reg/rec? sounds a pain, but £40 is £40, new battery
Old 18-12-09, 06:29 PM   #2
Dave20046
Dave20046's Avatar
Default Re: regulator/rectifier modifying?
People retro fit other models on I know the cbr reg recs fit with a bit of wiring modification. They cost £30 ish second hand and are supposedly superior. Need to do it meself soon
Old 18-12-09, 08:25 PM   #3
ocr_sv
http://cgi.ebay.co.uk/HONDA-CBR600-C...item3357c6e754
like this one, looks really similar, same number of wires, where can i get a wiring diagram tho?
Old 18-12-09, 08:47 PM   #4
boot
Read this thinking you'd got a flat tyre in the forest and was wondering how you sorted it. Oh well.
Plenty of info here http://eviltwinsbk.com/forumz/index.php?topic=276.0.
HTH
Old 18-12-09, 10:59 PM   #5
zunkus
I fitted a CBR one which uses mosfets instead of FETs which are better. It also has better charging than OEM. There are a few hints on how to install this on svrider.com I'd also ask Northy here who knows a thing or two. I've also changed the OEM wiring which was way too thin causing current drop. My system is much better now, bonus is better headlight and better ignition.
I need a Rectifier / Regulator. Marv Stuff Wanted 3 19-08-08 12:43 PM
Regulator-rectifier beaniebikerbabe SV Talk, Tuning & Tweaking 15 27-05-08 12:33 PM
Regulator/Rectifier? Biker Biggles SV Talk, Tuning & Tweaking 22 31-05-07 08:55 PM
K2 regulator/rectifier, new in box northwind For Sale - SV's and SV related items 0 22-02-07 09:14 PM
Regulator/Rectifier Steve T SV Talk, Tuning & Tweaking 3 10-10-04 10:34 PM
