Old 19-12-09, 09:19 AM   #1
Kinvig
Default Boiler Issues, again!
The old boiler has packed up. Again. And this time I can't fix it.
Checking the manual for the error code diagnosis, it suggests , "Turning it off and then back on again".
Boiler Fail.
Gotta leave for a Christmas do shortly and I really need a shower & shave! Guess I'll be the smelly, unkempt man on the train, then the hobo in the corner at the party.
Goddamnit!
Old 19-12-09, 09:22 AM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Boiler Issues, again!
Boiler Fail.
Goddamnit!
You not got a hot water cylinder with immersion heater?
2011 Speed Triple 1050
Old 19-12-09, 09:23 AM   #3
beabert
bucket and a kettle.
Old 19-12-09, 09:25 AM   #4
Kinvig
Nope.
Old 19-12-09, 09:35 AM   #5
dirtydog
Knob faced knobster
dirtydog's Avatar
Nope.
Bummer!
Old 19-12-09, 12:01 PM   #6
timwilky
timwilky's Avatar
I used to think it was best of both worlds a nice 10.5kw eleccy shower and a gas boiler. until the eleccy failed last christmas for 2 days. House was freezing, couldn't get a bath or shower.
fortunately I had learned a lesson from previous failures and have a little 2.8kva genny. so at least we had light unlike the neighbours and this year we now have a gas fire that ignites from a battery pack so the lounge should be warm when the eleccy goes again.
Off to fire up the genny just to make sure it will run when needed.
Not Grumpy, opinionated.
Old 19-12-09, 12:58 PM   #7
Spiderman
Where the hell am I?
Spiderman's Avatar
thats the answer mate. And while the kettle boils and you use that to go off and have a shave make sure you have a couple of pans of water on the cooker getting good and hot for a mini shower, the type where you just wash all the smelliest bits with a face cloth. "Cat licks" i call it.
Old 19-12-09, 03:05 PM   #8
svdemon
What boiler is it and what error code is it showing?
Old 20-12-09, 03:36 PM   #9
Kinvig
Vokera Linea 24. Error code 01, "Failure to ignite". Bizarrely, about 30 minutes ago it has decided to work again.....for how long is anyone's guess! (Probably as soon as I get in the shower....!).
Ideal Boiler Help - Any Plumbers/Gas fitters? krhall Idle Banter 8 01-09-09 07:29 PM
Plumbers - combi boiler question steveg Idle Banter 28 04-11-08 09:11 AM
Combi-boiler advice JediGoat Idle Banter 19 14-02-08 01:50 PM
Central Heating Boiler Reckless Rat Idle Banter 11 02-01-08 11:20 PM
gas boiler has gone steveg Idle Banter 14 06-10-07 10:46 AM
