Hello can some one help when i start my sv650 2000 xreg, it seems like there is a flow restriction like the exhaust is locked but i think its ok not looked at baffel wanting ideas before i start stripping parts down chees all
TONY |
What is the problem you're experiencing?
it starts on the button no probs but it seems to be fouling like there is a blockage in the exhaust and its popping alot while driving slow aprox 20 mph it judders
sounds like misfiring then???
defo back fired to day big time then judder like a chicken only get top speed when i rev up slowly
wrong gear? using up-shifting too many gears maybe, using 3rd when it should be 2nd etc... or is this an 'every time' sorta problem not intermittent? (sp?)
Ben. Edit: SV's back fire quite a lot anyway under deceleration. esp if you have an aftermarket can and no baffle. Last edited by BournemouthBen; 29-12-09 at 12:16 PM. |
its in 123rd gears seems to back fire and judder when i rev it at idle it struggles a bit and lacks power i know piston are fine friend do compression test but he is away now till june so he cant help me
you now how to strip and clean the carbs? this is where the problem will be but really you need to wait for spannerman or yc to tell you for sure
#9 |
Sounds like water in juice or a holed diaphragm, or could be a coil or HT lead breaking down under load.
#10 |
see I stand corrected, like normal
Restriction | GeneticBubble | Bikes - Talk & Issues | 18 | 23-06-12 10:23 PM |
Restriction cost? | sv_patterson | SV Talk, Tuning & Tweaking | 18 | 10-04-10 11:46 AM |
New restriction | suzsv650 | SV Talk, Tuning & Tweaking | 6 | 20-04-09 10:25 PM |
33 bhp de restriction HELP | andy gooding | Bikes - Talk & Issues | 33 | 19-02-06 12:01 PM |
restriction | jonnyb | SV Talk, Tuning & Tweaking | 27 | 27-04-05 08:51 AM |
