Old 01-01-10, 02:07 PM   #1
pikeman
Default battery access
Hi all,
new member here and a bit of a daft question to start with !!
My wife has a 650s (2007) how do i get to the battery, the rear part of the seat comes off with the key, but the basttery is under the rider part of the seat and i cant see how to get that off.
Help please
Old 01-01-10, 02:10 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: battery access
The battery is under the rides seat.
Underneath the riders seat, is a black plastic infill on each side of the bike, undo the allen key headed bolts that hold those on and then pop them off.
Then you should be able to see the bolts that hold the riders seat on. Undo those and lift the seat off.
There might be a black plastic tray under the seat, I cant remember on your model year SV. If there is lift it of and out of the way and then you will be able to see the battery.
Old 01-01-10, 02:11 PM   #3
On the curvy you remove the riders seat by removing the plastic infil panels with an allen key, then remove the riders seat by removing the allen keys that hold that on.
Think its similar on the pointy too?
Get yourself an accumen charger and the weatherproof charging socket, saves all this fuss and hassle.
http://www.accumate.co.uk/
Old 01-01-10, 02:16 PM   #4
pikeman
Thanks for that, thought it might be simpler and not need tools !!
Anyway thanks again the wife has the sv650s and i have a klv1000 so at least i have an sv1000 engine in my bike
Old 03-01-10, 09:34 PM   #5
disco
There are instructions how to get to the battery in the sv650 manual but the above answers are right also in the manual are instructions how to get to the toolbox/pouch which has the tools needed to get to the battery.
Hope this helps
MS Access help! andyb Idle Banter 4 17-12-09 04:53 PM
Anyone got or have access to... zedleppelin1981 Soho Massive 0 01-10-07 02:54 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
