Old 06-01-10, 04:49 PM   #1
sel1960
Default Exhaust can Remus lambda sensor.
Hi everyone im going to fit remus can to stock system will it make any problems with lambarda sensor,sv650 2007 thanks
Old 06-01-10, 05:24 PM   #2
PaulSV
Default Re: Exhaust can remus lambada sensor
not if its only the end can your changing, you should be cutting the standard pipe past the sensor.
Old 06-01-10, 05:43 PM   #3
take the sensor off before you cut or mess with the pipe. they are quite delicate and easy to break. you dont want to know the price of a new one as they are a specific type and are not available as an after market item.
Old 06-01-10, 07:51 PM   #4
sel1960
Thanks guys just wanted to be sure so i will remove the sensor before i cut the pipe
Old 06-01-10, 07:57 PM   #5
Alpinestarhero
measure twice, cut once
Old 06-01-10, 08:05 PM   #6
sel1960
sounds like good advice thanks
Old 06-01-10, 08:59 PM   #7
TazDaz
...or cut it first time roughly 5cms to the left of the weld?
Old 06-01-10, 09:01 PM   #8
zsv650
i used permanent marker where too cut and a grinder and marvelled at the spark's and destruction created.
Old 07-01-10, 06:08 PM   #9
sel1960
Smile Re: Exhaust can Remus lambda sensor.
Thanks everyone
Old 05-06-10, 03:08 PM   #10
Zen Beetle
Default Re: Exhaust can Remus lambda sensor.
I'm pretty sure that the K7 onwards annoyingly have a catalitic converter situated just about where you are going to cut. I think that the cat ends somewhere near the 55mm mark from the weld. Can somebody who has cut a K7/K8/K9 exhaust please advise me where to cut in order to avoid cutting the cat? I have ordered a Blue Flame can and so will face a similar dilemma soon.
Lambda sensor removal pipey Mini-Twins 7 04-02-09 12:35 PM
Lambda Sensor - errr.... ooger Idle Banter 23 16-07-08 05:17 PM
Lambda sensor k7/k8 DANINPLYMOUTH Bikes - Talk & Issues 0 20-04-08 06:03 PM
Lambda sensor on 08 bike nicollow SV Talk, Tuning & Tweaking 2 31-01-08 11:04 PM
remus exhaust bigspud SV Talk, Tuning & Tweaking 8 15-12-07 03:20 PM
