View Poll Results: How long is your heating on each day?
24 hours 15 26.32%
20-24 0 0%
15-20 5 8.77%
10-15 8 14.04%
5-10 20 35.09%
less than 5 11 19.30%
Multiple Choice Poll. Voters: 57. You may not vote on this poll
Old 07-01-10, 07:20 PM   #1
Binky
Emily Howard rides an SV
Binky's Avatar
Default How long is your heating on each day?
As title says.
I was surprised to hear a friend has her heating on 24 hours a day. Obviously she tends to be at home most of the day, but when i go to sleep i switch it off.
How long is yours on each day, and how long do you tend to stay at home for?
E.g. Work from home or looking after children etc...
Wowee Zowee
Old 07-01-10, 07:33 PM   #2
madness
Default Re: How long is your heating on each day?
My heating is technically swithed on all day, but it's controlled by a room thermostat on the landing which turns it on and off to maintain a pre-set temperature. So technically speaking it's not on all day. I used to have it come on in the morning for a couple of hours and then again in the evening, but the house never seemed to warm up properly. Now if the background temperature isn't warm enough I just turn the thermostat up a degree or so. It might not be the most economical way of running the central heating but it stops the house getting too cold and helps reduce dampness and condensation.
Old 07-01-10, 07:35 PM   #3
fizzwheel
fizzwheel's Avatar
As above, on all day, but controller with a room thermostat.
I found that because the house never gets cold, the boiler / heating doesnt run as much and when I get home from work or up in the morning I dont whack the heating right up on full because its so darn cold.
Old 07-01-10, 07:40 PM   #4
Spiderman
Where the hell am I?
Spiderman's Avatar
currently in this cold weather all day at 20 odd degrees, well this is at my mums house. At my own place its same story but at about 15/17 degrees.
Old 07-01-10, 07:41 PM   #5
husky03
all day-wife and three sprogs to keep warm
Old 07-01-10, 07:42 PM   #6
Dave20046
Dave20046's Avatar
turn it on for a couple of hours in the morning and a few hours in the evening.
Old 07-01-10, 07:45 PM   #7
kellyjo
At home all day with youngest, comes on at 5am and off at 8pm when they are in bed. When they're at their dads i turn it off and live in the lounge with the fire on as i have a large 4 bed house and its silly to heat it when im the only occupant. Either that or my boyfriend keeps me warm
Old 07-01-10, 07:45 PM   #8
at the moment its 24/7.
Old 07-01-10, 07:54 PM   #9
G
Mine come on between 5:30 and 9:30... then again at 16:30 until 22:30
At the moment it is on 24hrs though as we have been working from home.
Old 07-01-10, 07:59 PM   #10
lily
Ours is economy 7 so the storage heaters draw down the electricity to heat them over night (when cheaper) and then we have it set on the lowest setting to slowly discharge the heat thoughtout the day meaning that the appartment is always warm. So you may class it as being on all day i suppose
Central heating rpwoodman Idle Banter 10 05-01-10 12:47 PM
Central Heating the_lone_wolf Idle Banter 34 04-11-09 01:23 PM
Carb Heating hallasv Stuff Wanted 0 27-04-09 07:43 PM
Underfloor Heating Gazza77 Idle Banter 9 10-06-08 08:17 AM
Conservatory Heating Tris Idle Banter 15 16-01-07 10:24 PM
