Old 17-01-10, 06:15 PM   #1
stevegr
Default Broken key in filler cap
My SV650S has got the bottom part of my key stuck in it thanks to the recent weather.
I have got a replacement filler cap but how do I remove the old one?
Without blowing myself up that is!
Old 17-01-10, 08:01 PM   #2
bobbleheadbarne
Default Re: Broken key in filler cap
do you have a spare if so try putting it in then attach to a magnet while key is in or drill through where key goes, clean tank well then new fuel, or locksmith i had my disc lock go today they are hell to get off but i done it with hack saw, sorry to hear you bad news good luck
Old 18-01-10, 12:23 AM   #3
BanannaMan
BanannaMan's Avatar
A little wd-40 sprayed in the keyholes from time to time will prevent that.
I had the same thing happen on a previous bike.
A locksmith got it out and made a new key using the 2 pieces in about 30 mins.
...Bill
Old 18-01-10, 01:04 AM   #4
fastdruid
fastdruid's Avatar
If you can't get the key out with needle nose pliers then you should be able to either use a screwdriver to turn the lock or if all else fails use brute force to break it.
Druid
Old 18-01-10, 07:49 PM   #5
davepreston
well since you still have the other half of the key unlock it and just remove the screws round the top of the cap it then comes off in one unit, replace with new one simples
filler cap mikelcfc SV Talk, Tuning & Tweaking 0 14-09-09 08:59 PM
Radiator filler cap wizurd Bikes - Talk & Issues 6 20-06-09 10:08 PM
Startrek.steve broken, SV650 broken too startrek.steve Bikes - Talk & Issues 31 26-08-08 12:49 PM
Broken dreams and broken lives. Peter Henry Idle Banter 7 15-09-06 07:43 AM
oil filler cap SVeeedy Gonzales SV Talk, Tuning & Tweaking 13 03-02-06 12:05 PM
