Old 21-01-10, 02:27 PM   #1
Taipan
Taipan's Avatar
Question Possible developing oil leak?
I think I may have an oil leak from around the gearbox sprocket or gear change shaft, certainly on that side in that sort of area anyway. Are the Curvys known for any particular oil seal fails around there? Assuming it is one of them how bad a job is replacement?
Many thanks.
Old 21-01-10, 02:29 PM   #2
Dave20046
Dave20046's Avatar
Default Re: Possible developing oil leak?
I've read somewhere about it running from one of the shafts or possibly clutch pushrod out of the engine (read it on here I think). Might be worth taking the sprock cover off to have a gander.
Old 21-01-10, 03:50 PM   #3
It could be worth checking that you haven't adjusted your chain too tightly, or at least one part is less stretched than the rest.
Reason I say is because I developed an oil leak from the sprocket area and it was the rubber sprocket seal that had moved enough to let oil out, after the chain had been adjusted. Brand new chain but half of it decided not to wear at the same rate as the other.
Was a head scratcher at the GM last year. Sat on the bike and the chain went so tight there was no movement. Backed it off and it has been fine since, as the sprocket seal re-seated itself.
Old 21-01-10, 05:07 PM   #4
Dave20046
Dave20046's Avatar
Had you been training for the bobsled team?
Old 21-01-10, 05:53 PM   #5
phnar!
NO cheeky git!.
It was just the way the chain had worn in. Badly adjusted in the way it had only been looked at on one half, and we thought it needed it. The other half was too tight....suprised it didn;t do a Gr33k and snap on the motorway!
Old 21-01-10, 06:11 PM   #6
Dave20046
Dave20046's Avatar
phnar!
NO cheeky git!.
hehe, was only jokin that's why I wheel the bike til the tightest bit of the chain is under the swing arm then sit on it lean back and feel the slack.
Old 21-01-10, 06:16 PM   #7
Its ok for you, you have arms like apehangers..long!!
I knows you're kidding. But it wasn't me that adjusted it. It was Carnivore. Mind you it was him that told me what it was straight away, as soon as he saw the leak, without even looking at the chain. The evidence only backed up his first guess..jammy git!
Old 22-01-10, 01:03 PM   #8
vardypeeps
Scottoiler turned up too high?
I;ve had this before where it's collected behind the front sprocket cover (still wet) and then dripped down looking like an oil leak.
Don't start you engine with the clutch push rod removed as it squirts out everywhere (D'oh)
Old 28-01-10, 03:49 PM   #9
Taipan
Taipan's Avatar
Its definitely engine oil thats coming out. I cant work out if its the gearbox seal or the clutch pushrod one? I'll clean it up at the weekend and see which one it is. What sort of job is replacing these?
Old 28-01-10, 04:32 PM   #10
fastdruid
fastdruid's Avatar
Oh yes it does, and boy does it go a *long* way!
Druid
Oil Leak :-( stephencassidy SV Talk, Tuning & Tweaking 11 07-10-09 06:31 PM
Property Developing squirrel_hunter Idle Banter 19 08-08-09 07:58 PM
Has anyone done any property developing? rob13 Idle Banter 6 03-09-07 02:13 PM
Gas leak! imaleon Bikes - Talk & Issues 10 06-05-06 03:23 PM
Not oil leak - Petrol leak - double "Bugger"...! Potts SV Talk, Tuning & Tweaking 1 17-10-04 08:16 PM
