Old 22-01-10, 01:49 PM   #1
yiangu
Default Wet Weather Idle
Hello to you all!
I have an SV650 SK1 2001 Model full fairing, it is in great nick only 10k on the clock and I always look after it, I have noticed that in the rain the idel runs lumpy it keeps dropping from 1300 to about 800 then bouncing back up again when I am at a stan still?
only seems to do it in the rain???
Does anyone have any ideas on what it could be?
Cheers Yan the Bubble
Old 22-01-10, 01:51 PM   #2
LK-SV
Default Re: Wet Weather Idle
Wet front spark plug .... loads of threads/posts on here about it .... do a search ...
Welcome btw ....
Old 22-01-10, 01:57 PM   #3
yiangu
Thank you for the quick response, I will take a look at the front plug this weekend
Old 22-01-10, 02:00 PM   #4
yiangu
If anyone has any other great solutions appart from adding a front mudguard extender please fire away..
Old 22-01-10, 02:05 PM   #5
ophic
ophic's Avatar
1st step - spray wd40 down the drain hole.
Silver SV650SK3, Fuel exhaust
Old 22-01-10, 02:05 PM   #6
On one of my SVs I have a very thin plate (can't remember if its plastic or metal) its hung off the back of the radiator and covers the front cylinder lovely. Defo no problem in three years of having front plug drowning in the rain
The other one has a fender extender. Never had a problem with the front plug on that one drowning in rain either
Old 22-01-10, 02:54 PM   #7
Holdup
I sprayed a bit of ignition drier in the plug cap last service i did on it and havent had any touble since another solution is grease, not sure which tho
Old 22-01-10, 03:42 PM   #8
The Guru
A tube of silicone grease.
Old 22-01-10, 03:42 PM   #9
yiangu
Thank you
Who needs expensive garage bills..
Old 22-01-10, 04:26 PM   #10
Anyone in riding distance of my house
Varying Idle crzylanesplit SV Talk, Tuning & Tweaking 4 26-10-08 11:39 AM
Idle again! Jamie_SV SV Talk, Tuning & Tweaking 2 08-03-08 03:30 PM
IL4 Idle... DeeJay Bikes - Talk & Issues 26 26-05-05 03:11 PM
