Old 27-01-10, 11:51 AM   #1
Lost@Home
Default Where is my flasher relay(s)?
Hi all,
I have an SV650 (strangely enough) SK4 and I want to replace my front flasher relay.
So I can do this in the quickest possible time can some body tell me where it is located on the bike.
Much appreciated!
Old 27-01-10, 11:55 AM   #2
fastdruid
fastdruid's Avatar
Default Re: Where is my flasher relay(s)?
On the curvy its under the front seat next to the fuse box, dunno about the pointy.
There isn't separate relays for front and back btw, its all or nothing.
If only your rear indicators are working then you have a different problem.
Druid
Old 27-01-10, 12:46 PM   #3
Lost@Home
will have a look under the front seat to see if i can find it there.
i have just bought some LED front flasher, still go standard lamps on the tail. was looking at replace the relay but looks as though i may need to take the resistor option instead.
Old 27-01-10, 12:49 PM   #4
fastdruid
fastdruid's Avatar
The fiche seems to imply its in the same'ish place, certainly find the fuse box, find the relay.
Druid
Old 27-01-10, 08:58 PM   #5
Rammsteinkid
i did this, i thought i had a flasher relay and turn out i did since i have minis on the rear.
just soldier the new indis wire onto the exsisting one and you should be ok. If you really do have a flasher relay that is.
Old 30-01-10, 02:51 PM   #6
Lost@Home
Unfortunatly I don't ave a flasher relay. I've got the later style 7 pin relay that handles the side stand cut, fuel pump etc and the only one I can find on eBay in the UK is about £40. Its either that or resistors, can anybody offer any help?
How to Wire Hein Gericke Flasher Relay BomBalong SV Talk, Tuning & Tweaking 7 30-08-09 04:11 PM
LED Flasher Problems thedon1000 Bikes - Talk & Issues 0 28-02-09 04:37 PM
problem with flasher relay. fourstrokebeast SV Talk, Tuning & Tweaking 10 30-03-08 07:22 PM
WANTED asap flasher/multi function relay sv650k4 Stuff Wanted 6 24-01-08 09:59 PM
Flasher Relay installation - might have done something bad... R-Razor SV Talk, Tuning & Tweaking 7 07-10-07 12:28 AM
