Old 27-01-10, 06:59 PM   #1
Geodude
Geodude's Avatar
Default Low revs?
Dont know if this is just a cold weather problem? When bike is started it runs and idles fine but when you pull away or rev the engine it wont go above 3k revs and it sounds muffled? Bikes got new plugs and carb plungers ar'nt sticking either.
Old 27-01-10, 09:42 PM   #2
5hort5
Default Re: Low revs?
If you rev it hard does it die? If yes then drain the carbs and check the fuel tank for water, then check your drain plug in the filler cap and that water is getting out of the pipe on the back, underside of the tank.
5hort5 is offline   Reply With Quote
Old 28-01-10, 09:07 AM   #3
Geodude
Geodude's Avatar
It does'nt die when revved hard but i will check fuel tank for water.
Hissing at certain revs DarrenSV650S SV Talk, Tuning & Tweaking 3 24-10-08 03:05 PM
how do you lot ride what revs jans1971 Bikes - Talk & Issues 20 05-09-07 07:04 AM
8k revs and nothing happens!!!! help vsumouse SV Talk, Tuning & Tweaking 15 28-01-07 03:51 PM
idle revs...... keithd SV Talk, Tuning & Tweaking 3 13-07-05 11:17 AM
speed/revs will SV Talk, Tuning & Tweaking 14 21-04-05 06:46 PM
