Old 28-01-10, 08:09 PM   #1
Default My polishing thread
After following Liam’s polishing thread I picked up some tip on polishing, which I used to polish up my USD forks prior to doing the front end swap in the next couple of weeks.
Forks were ok in standard trim no corrosion, but could look better
Here's a before and after together. On the unpolished fork are the oringinal machining marks, which I had to remove using a detail sander & 80grit paper
Then I used some 80 grit compound, followed by some 240 and then the green compound followed by the blue in my kit. It was nice to go from the 240 grit to the green as the chrome effect magically appeared.
Here's the top yoke, it hasn't polished up so well, as the alloy seems to be of a different quality? But it'll do, it was pretty scabby
Both forks together, luckily one had already been polished, as the one I did took nearly 3 afternoons to do, although some of this was waiting for the paint stripper to do its stuff. However this might have been time wasted, as I don't think the forks had any lacquer on them at all, as nothing was removed by the Nitomors?
The one I polished is on the right
Old 28-01-10, 08:12 PM   #2
svrich
Default Re: My polishing thread
Nice. You can have a go at mine in March if you like
Old 28-01-10, 08:30 PM   #3
Dream on, you need the patience of a saint to do the forks
Smooth stuff like the swingarm & yoke is a doddle compared to those barsteward forks.
Plus I've got to clean up the down pipe after our last rideout
Old 28-01-10, 08:36 PM   #4
svrich
It was worth a try.
Old 28-01-10, 08:41 PM   #5
It was worth a try.
Paint or powder coat is another quick way, hides all kinds of carp
Old 28-01-10, 08:45 PM   #6
5hort5
Nice post mavicap, I plan to do mine later in the year so it's nice to see what can be achieved.
5hort5 is offline   Reply With Quote
Old 28-01-10, 08:49 PM   #7
speedplay
Ill send you my heel plates...
Old 28-01-10, 08:52 PM   #8
Dey ain't so bad, but I still got mine to do. They polish up nice too
Old 28-01-10, 08:54 PM   #9
speedplay
And the swingarm off my KTM...
And the sub frame...
Cheers mate
Old 28-01-10, 08:54 PM   #10
Update tomorrow, as I painted the lower part. Too fidley to polish this year. Bike has to be back on the road by 7th March, otherwise SvRich is going to beat me with a big stick if I can't make the EAR rideout
For those who like polishing... Nobbylad Idle Banter 2 17-07-09 11:05 AM
Polishing my can...... davidimurray SV Talk, Tuning & Tweaking 14 26-09-07 03:22 PM
Polishing _Stretchie_ Photos 13 07-02-07 10:52 AM
polishing. kwak zzr SV Talk, Tuning & Tweaking 2 25-06-06 07:09 PM
Polishing alex.j SV Talk, Tuning & Tweaking 7 16-02-06 02:03 PM
