Old 29-01-10, 12:16 AM   #1
metalhead19
Default Intermitant brake light
When pulling in the brake lever I noticed tht the brake light flickers on and off n at points when applying the brake the light is not on..... Am unsure wht could be causing this.
Any ideas?
Old 29-01-10, 07:31 AM   #2
Default Re: Intermitant brake light
The switch has dirty contacts, is loose or the connections aren't fitted properly/are damaged.
Make sure it's fitted properly first, that the spades/connector block are/is on right, and that the cables are undamaged. Try squirting some contact cleaner into the switch, (inside it, not just over it), it's not intended that you do but if you're careful it can be disassembled.
Old 29-01-10, 08:44 PM   #3
embee
embee's Avatar
As the Squid says, very likely dirty/burnt contacts in the switch. I had exactly this problem.
They are designed so the contacts flick closed due to an overcentre spring arrangement (the click you hear), then as you continue to press the button in the contacts "wipe" slightly in theory to keep them clean. On mine the light would come on at the click but then go off as you pulled the lever further due to dirt just away from the first contact point.
Filling the switch with contact cleaner (or WD40 will do) and clicking it repeatedly will probably sort it.
The switch block casing has 3 plastic pegs which are melted over to hold the 2 halves together. They can be carefully prised apart at these pegs and then you can clean them properly. I didn't re-glue it, the fixing screw holds it together. I filled it with vaseline, it's been fine for several years now.
If all else fails they are not particularly expensive.
Old 29-01-10, 08:54 PM   #4
Rob969
Mine did the same after not riding it for 3 months as everyone else has said try a little squirt of wd40 or electrical contact cleaner and lots of exercising of the brake lever.
Old 29-01-10, 11:13 PM   #5
metalhead19
Ok cheers for all the suggestions guys! Il give some WD a try and see if that sorts it with some exercise of the lever.
Brake light not coming on with rear brake. XmisterIS SV Talk, Tuning & Tweaking 5 11-12-09 12:06 AM
Brake light switch sticking on with front brake rick0361 SV Talk, Tuning & Tweaking 6 11-06-09 06:20 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
Neither Brake lever works the brake light anymore kellie000 SV Talk, Tuning & Tweaking 13 29-12-06 12:15 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
