Old 02-02-10, 11:07 AM   #1
mikebrooman
Question Delayed High Beam
Another gremlin in my electronics, maybe someone can explain.
My high beam didn't work for ages, so I took the front apart and found the dodgy connection (in the yellow box on the left of the bike leading from the handlebar switch). Now my high beam has a delay the first time I use it. E.g.
Flick the switch, all lights go out, then 0.5 seconds later high beam comes on.
Not a massive issue, except for when you want to use high beam, you normally are in quite a dark place, so half a second of dark isn't great.
The strange thing is, when I've recently turned them on and experienced the delay, the next time I turn them on, there is no delay.
It is like they need warming up, and then next time they are already warm (like energy saving bulbs for example).
Not sure the length of time required to set them back to the delayed bit is.
Can anyone explain this and hence help fix it?
Thanks
Old 02-02-10, 10:44 PM   #2
Default Re: Delayed High Beam
No. But seeing as the previous problem was due to the connector block I'd first look there again - just to be sure.
Old 04-02-10, 09:30 AM   #3
Ceebl
You havnt accidentally fitted an HID or xenon high beam kit and forgotten about it? No? Haha
Old 04-02-10, 10:47 AM   #4
punyXpress
punyXpress's Avatar
He claims to have : " HI Intensity Lights "
Now: Street Triple R
Old 04-02-10, 01:02 PM   #5
Ceebl
Xenon gass in sum aftermarket lights takes a second to heat up
Lost Dipped Beam on K3 I'm_a_Newbie SV Talk, Tuning & Tweaking 16 01-12-09 10:05 AM
H.I.D H4 for sv hi low beam ging6996 For Sale - SV's and SV related items 4 28-07-09 04:49 PM
No High Beam - but there is voltage (and yes the bulbs are ok...) chris7231 SV Talk, Tuning & Tweaking 8 25-03-09 12:28 PM
low beam not working. Slash SV Talk, Tuning & Tweaking 3 26-09-08 02:28 PM
High-beam light simesb SV Talk, Tuning & Tweaking 2 27-03-08 07:22 PM
