Old 03-02-10, 11:25 AM   #1
warrenhewitt10
Default 12V socket
im possibly driving to the moto gp in catalunya, and i want to buy a 12v socket to charge my iphone while im driving, i have one question about these tho, i know they come with fuses, but when the bike is up at running the socket will be getting like 14.5v, which im suspecting might be damaging to my iphone
i had a cheap Chinese plug>usb charger for my ipod touch a while back which ran at 5.2v rather than the 5v a usb port is ment to be, and this properly messed up the touch screen, so an extra 2.5v worries me
is this a problem?
Old 03-02-10, 12:14 PM   #2
Sally
Default Re: 12V socket
Just charge it while you stop?
Old 03-02-10, 12:16 PM   #3
Alpinestarhero
Could you not put a resistor in the circuit?
Old 03-02-10, 12:18 PM   #4
warrenhewitt10
haha true but not the solution im looking for! theres lots of these things on ebay, if it was a huge problem id think ppl wouldnt buy them, im just concerned that it will kill my iphones battery
Old 03-02-10, 12:30 PM   #5
Taipan
Taipan's Avatar
Its the same voltage as you get through a car charger? Surely proper iphone ones are suited for this?
Old 03-02-10, 12:34 PM   #6
Sally
In theory.
Buy a cheapo 12v connector.
Buy needed fuse.
Buy OEM Apple charger.
Thats what I did when I made mine, just wasnt an iPhone.
Havent tried charging it with the bike running though... :\
Wait for someone with more electrical sense than me.
Old 03-02-10, 12:36 PM   #7
timwilky
timwilky's Avatar
get a £5 12v regulator in the line before the socket
click on it for details
Not Grumpy, opinionated.
Old 03-02-10, 12:38 PM   #8
Stu
Trinity
Stu's Avatar
I'd be surprised if they did. Easy enough to add though
+1
Old 03-02-10, 12:40 PM   #9
ophic
ophic's Avatar
I sincerely doubt that the 0.2V difference caused your problem, and also raises the question of how you measured it - 5.2V open circuit will most likely drop to 5V or below under load, due to internal resistance in the source. Even batteries vary by more than 0.2V over their charge cycle, and also with varying temperatures.
I would expect a car socket to go even higher than the SV's, as I believe cars tend to charge at a slightly higher voltage than bikes, which is why they recommend jump starting a bike from a car with the car engine off, or else the reg/rec gets fried.
Silver SV650SK3, Fuel exhaust
Old 03-02-10, 12:56 PM   #10
TC3
I put a power socket on the bike. In Tesco i found a Griffin plug that goes into the socket. It has 2 usb connections and it came with a black iphone usb charger lead. Works very well and powers my satnav as well as charges the phone no troubles at all. Only cost under 12 quid. I had originally got a plug that goes in the power socket and has connection for a single usb, from ebay but that was crap and did not work.
This is what i got and has a resettable fuse
http://www.griffintechnology.com/pro...owerjoltiphone
12v socket installation. Specialone SV Talk, Tuning & Tweaking 16 12-12-10 11:02 AM
Which socket set? MGI SV Talk, Tuning & Tweaking 12 23-01-10 03:42 PM
12V Cig Socket Socket Etc. Sally SV Talk, Tuning & Tweaking 48 05-11-09 01:36 PM
what size socket? larigos SV Talk, Tuning & Tweaking 6 30-03-09 12:17 PM
Socket sets dmracing SV Talk, Tuning & Tweaking 35 26-08-07 11:08 PM
