Old 08-02-10, 05:52 PM   #1
redlavachips
Default starting problems
hi guys, long time no speak , anywho back on topic, decided to try and start the old sv today , with no luck. then decided to try and bump start it down the hill ( i live at the top of a hill you see) but it didnt start ( roads still a bit slippy didnt help) so pushed it back up the hill and decided to screw doing that again and get a battery charger , so put the charger on and it said it was about 11.6 volts , so let it charge for a while and it wouldnt charge above 12.6 , so put the battery in the bike and still no luck , all it is doing is lights going out and abit a clicking sound and might turn the engine once over when trying to start , then dead again, in thinking a short but wasnt having a problem last time i used it , any comments will be most useful, kind regards red
Old 08-02-10, 05:58 PM   #2
Sosha
Default Re: starting problems
My money would be on dead battery...try a longer charge? got jump leads? what's the voltage after you've attempted to start it a few times?
Old 08-02-10, 06:05 PM   #3
redlavachips
only brought the battery last year and what the normal charge of a battery
Old 08-02-10, 06:06 PM   #4
davepreston
yep dead battery most likely when was the last time you ran it, jump leads and voltmeter are your mates here
Old 08-02-10, 06:11 PM   #5
davepreston
13.6v -14.6v
idle-charging on bike
Old 08-02-10, 06:11 PM   #6
redlavachips
ran it in late november, ive got jump leads on my charger will they work??? will i need a new battery??
Old 08-02-10, 06:30 PM   #7
davepreston
try to jump off the charger see if that works, then test with voltmeter while its running to see if its raising the volts, 2 months left alone in the cyrrent sh1tty weather may kill a battery so you may need a new one, look up batteryman on the org for a new one (its his buisness), hopefully a good run will get it sorted for you
Old 08-02-10, 06:31 PM   #8
davepreston
remember these arent car batteries which you can leave forever i turn my bike over for 10 mins every 2 weeks
Old 08-02-10, 06:33 PM   #9
redlavachips
true will try tomorrow , thankyou for the advice
Old 08-02-10, 06:40 PM   #10
TBH you're better off just charging the battery. I don't like running engines unless you're going to take them for a decent ride (20 miles), you're putting acidic combustion wastes into the oil which won't be good for it.
Plus you wasting petrol lol.
One advantage I can see though is you keeping fresh petrol moving through a carbed bike which is good to do unless you are going to drain the carbs over winter.
Starting Problems richardh SV Talk, Tuning & Tweaking 10 11-01-09 09:29 PM
Starting problems mbuk SV Talk, Tuning & Tweaking 3 12-12-07 11:02 AM
Starting Problems! squirrel_hunter SV Talk, Tuning & Tweaking 20 07-12-05 12:08 AM
Problems starting riktherider SV Talk, Tuning & Tweaking 4 11-06-05 06:13 PM
Starting problems squirrel_hunter SV Talk, Tuning & Tweaking 2 14-05-05 09:37 PM
