Old 09-02-10, 07:27 PM   #1
ricky
Default sv curvy rear rack how much weight can it take?
as above how much can they take, got one and seen the weight sticker is saying max 2kgs but want to use it to carry tent that's 7kgs
Old 09-02-10, 08:04 PM   #2
Default Re: sv curvy rear rack how much weight can it take?
Loads more. Have had the rentec racked up to the eyeballs....even a ten kilo tent with sleeping bags on top.
HTH
Old 09-02-10, 08:25 PM   #3
Lucas
lots, had a 4 men tent on it + sleep bag and mat, and was fine
Old 09-02-10, 08:31 PM   #4
Taipan
Taipan's Avatar
Timely thread. Just considering buying a Rentec but wondered if it was up for the job of holding a 45l top box with clothes and shoes in. Looks like it will then!
Old 09-02-10, 08:36 PM   #5
Just be aware that they do flex a lot, by that I mean I use my grab rail a lot for man handling the SV around, if the racks on I don't..as it flexes.
Shouldn't put you off though, they're as tough as
Old 09-02-10, 08:36 PM   #6
Lucas
you can lift the bike up with it, be it may flex a bit!
Old 09-02-10, 08:49 PM   #7
ricky
cool cheers just fitted it to the bike and put the tent on to try it all out then tent is got to be about 8kg and didnt really move the rack, im hoping to put the tent the sleeping backs and sleeping beds on the rack itself
Old 09-02-10, 09:05 PM   #8
Lucas
just make sure you fix down the luggage securely before speeding off!
i usually put everything in a big bin bag first, it helps to keep stuff together and make it easier to tie down, and stays dry if it rains
Old 09-02-10, 09:24 PM   #9
ricky
col cheers for the tip
Old 10-02-10, 09:36 AM   #10
Actually my subframe is cracked from loading all manner of crap on the rack!
But you can safely ignore the 2kg thing.
I do not think they are beefy enough for a topbox though, IMO you want one of those racks with the bottom brace to mount to the pillion peg bolts.
WTB rear luggage rack for a curvy mikereno1 Stuff Wanted 1 21-06-08 03:54 PM
sv650s curvy bar end weight wanted adam_castell Stuff Wanted 3 07-05-08 05:25 PM
Rear Rack Wanted stitch Stuff Wanted 0 20-12-07 07:32 AM
rack thing under the rear tail lancasterlad SV Talk, Tuning & Tweaking 3 27-07-07 09:42 AM
Renntec Rack Weight Limit pups3000 SV Talk, Tuning & Tweaking 8 16-07-07 12:55 PM
